Problem reading ADXL362 data using Teensy 4.1 and Arduino IDE
I'm trying to read data from the ADXL362 accelerometer sensor using Teensy 4.1 and Arduino IDE.
Teensy libraries installed from:
https://www.pjrc.com/teensy/td_download.html
The ADXL362 library by Anne Mahaffey was installed using the ArduinoIDE library manager.
ADXL362 by annem
I also followed a tutorial by
This is a sketch of the connections using the SPI protocol.
I tried to run the SimpleRead code, but all the readings I got were always zero.
 ADXL362_SimpleRead.ino -  Simple XYZ axis reading example
 for Analog Devices ADXL362 - Micropower 3-axis accelerometer
 go to http://www.analog.com/ADXL362 for datasheet
 License: CC BY-SA 3.0: Creative Commons Share-alike 3.0. Feel free
 to use and abuse this code however you'd like. If you find it useful
 please attribute, and SHARE-ALIKE!
 Created June 2012
 by Anne Mahaffey - hosted on http://annem.github.com/ADXL362
 Modified May 2013
 by Jonathan Ruiz de Garibay
Connect SCLK, MISO, MOSI, and CSB of ADXL362 to
SCLK, MISO, MOSI, and DP 10 of Arduino
(check http://arduino.cc/en/Reference/SPI for details)
#include <SPI.h>
#include <ADXL362.h>
ADXL362 xl;
int16_t temp;
int16_t XValue, YValue, ZValue, Temperature;
void setup(){
xl.begin(10);                   // Setup SPI protocol, issue device soft reset
xl.beginMeasure();              // Switch ADXL362 to measure mode
Serial.println("Start Demo: Simple Read");
void loop(){
// read all three axis in burst to ensure all measurements correspond to same sample time
xl.readXYZTData(XValue, YValue, ZValue, Temperature);
Serial.print("XVALUE=");
Serial.print(XValue);
Serial.print("\tYVALUE=");
Serial.print(YValue);
Serial.print("\tZVALUE=");
Serial.print(ZValue);
Serial.print("\tTEMPERATURE=");
Serial.println(Temperature);
delay(100);                // Arbitrary delay to make serial monitor easier to observe
Things I've tried:
  1. Measure the signals of CLK, MOSI, and MISO pins using an oscilloscope. I didn't see any signal, but I'm not sure I did it correctly.
  2. I read it might be a floating pin issue that can be solved via pull-up resistors. Also, since the pin in Tessnsy has integrated pull-up resistors, there's a way to do it with software. I need guidance on how to implement this.
Thanks!
I noticed in the examples the SPI needs to be started.
SPI.begin();
I don't see that in your code.
Thanks for your reply.
The command SPI.begin() is included in ADXL362 begin (the code attached)
 Arduino Library for Analog Devices ADXL362 - Micropower 3-axis accelerometer
 Created June 2012
 Modified May 2013
#include <Arduino.h>
#include <SPI.h>
//#define ADXL362_DEBUG
int16_t slaveSelectPin = 10;
ADXL362::ADXL362() {
//  begin()
//  Initial SPI setup, soft reset of device
void ADXL362::begin(int16_t chipSelectPin) {
	slaveSelectPin = chipSelectPin;
	pinMode(slaveSelectPin, OUTPUT);
	SPI.begin();
	SPI.setDataMode(SPI_MODE0);	//CPHA = CPOL = 0    MODE = 0
	// soft reset
	SPIwriteOneRegister(0x1F, 0x52);  // Write to SOFT RESET, "R"
	delay(10);
#ifdef ADXL362_DEBUG
	Serial.println("Soft Reset\n");
#endif
//  beginMeasure()
//  turn on Measurement mode - required after reset
void ADXL362::beginMeasure() {
	byte temp = SPIreadOneRegister(0x2D);	// read Reg 2D before modifying for measure mode
	Serial.print(  "Setting Measeurement Mode - Reg 2D before = ");
	Serial.print(temp);
#endif
	// turn on measurement mode
	byte tempwrite = temp | 0x02;			// turn on measurement bit in Reg 2D
	SPIwriteOneRegister(0x2D, tempwrite); // Write to POWER_CTL_REG, Measurement Mode
	delay(10);
	Serial.print(  ", Reg 2D after = ");
	Serial.println(temp);
#endif
//  readXData(), readYData(), readZData(), readTemp()
//  Read X, Y, Z, and Temp registers
int16_t ADXL362::readXData(){
	int16_t XDATA = SPIreadTwoRegisters(0x0E);
	Serial.print("XDATA = ");
	Serial.println(XDATA);
#endif
	return XDATA;
int16_t ADXL362::readYData(){
	int16_t YDATA = SPIreadTwoRegisters(0x10);
	Serial.print("\tYDATA = ");
	Serial.println(YDATA);
#endif
	return YDATA;
int16_t ADXL362::readZData(){
	int16_t ZDATA = SPIreadTwoRegisters(0x12);
	Serial.print("\tZDATA = ");
	Serial.println(ZDATA);
#endif
	return ZDATA;
int16_t ADXL362::readTemp(){
	int16_t TEMP = SPIreadTwoRegisters(0x14);
	Serial.print("\tTEMP = ");
	Serial.println(TEMP);
#endif
	return TEMP;
void ADXL362::readXYZTData(int16_t &XData, int16_t &YData, int16_t &ZData, int16_t &Temperature){
	  // burst SPI read
	  // A burst read of all three axis is required to guarantee all measurements correspond to same sample time
	  digitalWrite(slaveSelectPin, LOW);
	  SPI.transfer(0x0B);  // read instruction
	  SPI.transfer(0x0E);  // Start at XData Reg
	  XData = SPI.transfer(0x00);
	  XData = XData + (SPI.transfer(0x00) << 8);
	  YData = SPI.transfer(0x00);
	  YData = YData + (SPI.transfer(0x00) << 8);
	  ZData = SPI.transfer(0x00);
	  ZData = ZData + (SPI.transfer(0x00) << 8);
	  Temperature = SPI.transfer(0x00);
	  Temperature = Temperature + (SPI.transfer(0x00) << 8);
	  digitalWrite(slaveSelectPin, HIGH);
	Serial.print("XDATA = "); Serial.print(XData);
	Serial.print("\tYDATA = "); Serial.print(YData);
	Serial.print("\tZDATA = "); Serial.print(ZData);
	Serial.print("\tTemperature = "); Serial.println(Temperature);
#endif
void ADXL362::setupDCActivityInterrupt(int16_t threshold, byte time){
	//  Setup motion and time thresholds
	SPIwriteTwoRegisters(0x20, threshold);
	SPIwriteOneRegister(0x22, time);
	// turn on activity interrupt
	byte ACT_INACT_CTL_Reg = SPIreadOneRegister(0x27);  // Read current reg value
	ACT_INACT_CTL_Reg = ACT_INACT_CTL_Reg | (0x01);     // turn on bit 1, ACT_EN
	SPIwriteOneRegister(0x27, ACT_INACT_CTL_Reg);       // Write new reg value
	ACT_INACT_CTL_Reg = SPIreadOneRegister(0x27);       // Verify properly written
	Serial.print("DC Activity Threshold set to ");  	Serial.print(SPIreadTwoRegisters(0x20));
	Serial.print(", Time threshold set to ");  		Serial.print(SPIreadOneRegister(0x22));
	Serial.print(", ACT_INACT_CTL Register is ");  	Serial.println(ACT_INACT_CTL_Reg, HEX);
#endif
void ADXL362::setupACActivityInterrupt(int16_t threshold, byte time){
	ACT_INACT_CTL_Reg = ACT_INACT_CTL_Reg | (0x03);     // turn on bit 2 and 1, ACT_AC_DCB, ACT_EN
	Serial.print("AC Activity Threshold set to ");  	Serial.print(SPIreadTwoRegisters(0x20));
	Serial.print(", Time Activity set to ");  		Serial.print(SPIreadOneRegister(0x22));
#endif
void ADXL362::setupDCInactivityInterrupt(int16_t threshold, int16_t time){
	SPIwriteTwoRegisters(0x23, threshold);
	SPIwriteTwoRegisters(0x25, time);
	// turn on inactivity interrupt
	ACT_INACT_CTL_Reg = ACT_INACT_CTL_Reg | (0x04);      // turn on bit 3, INACT_EN
	Serial.print("DC Inactivity Threshold set to ");  Serial.print(SPIreadTwoRegisters(0x23));
	Serial.print(", Time Inactivity set to ");  Serial.print(SPIreadTwoRegisters(0x25));
#endif
void ADXL362::setupACInactivityInterrupt(int16_t threshold, int16_t time){
	ACT_INACT_CTL_Reg = ACT_INACT_CTL_Reg | (0x0C);      // turn on bit 3 and 4, INACT_AC_DCB, INACT_EN
	Serial.print("AC Inactivity Threshold set to ");  Serial.print(SPIreadTwoRegisters(0x23));
#endif
void ADXL362::checkAllControlRegs(){
	//byte filterCntlReg = SPIreadOneRegister(0x2C);
	//byte ODR = filterCntlReg & 0x07;  Serial.print("ODR = ");  Serial.println(ODR, HEX);
	//byte ACT_INACT_CTL_Reg = SPIreadOneRegister(0x27);      Serial.print("ACT_INACT_CTL_Reg = "); Serial.println(ACT_INACT_CTL_Reg, HEX);
	SPI.transfer(0x20);  // Start burst read at Reg 20
	Serial.println("Start Burst Read of all Control Regs - Library version 6-5-2014:");
	Serial.print("Reg 20 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 21 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 22 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 23 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 24 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 25 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 26 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 27 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 28 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 29 = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 2A = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 2B = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 2C = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 2D = "); 	Serial.println(SPI.transfer(0x00), HEX);
	Serial.print("Reg 2E = "); 	Serial.println(SPI.transfer(0x00), HEX);
#endif
// Basic SPI routines to simplify code
// read and write one register
byte ADXL362::SPIreadOneRegister(byte regAddress){
	byte regValue = 0;
	SPI.transfer(regAddress);
	regValue = SPI.transfer(0x00);
	return regValue;
void ADXL362::SPIwriteOneRegister(byte regAddress, byte regValue){
	SPI.transfer(0x0A);  // write instruction
	SPI.transfer(regValue);
int16_t ADXL362::SPIreadTwoRegisters(byte regAddress){
	int16_t twoRegValue = 0;
	twoRegValue = SPI.transfer(0x00);
	twoRegValue = twoRegValue + (SPI.transfer(0x00) << 8);
	return twoRegValue;
void ADXL362::SPIwriteTwoRegisters(byte regAddress, int16_t twoRegValue){
	byte twoRegValueH = twoRegValue >> 8;
	byte twoRegValueL = twoRegValue;
	SPI.transfer(twoRegValueL);
	SPI.transfer(twoRegValueH);
Does your Teensy have an ethernet chip onboard? If so, it uses D10 for its SS.
D9 is also used as the ethernet reset. Don't use it either.
D4 is normally for SD cards. Don't use it.
