AFE4300 WITH DUE
HI,
i already posted my problem in Arduino DUE section , but no response . Kindly help me .
i am trying to connect the AFE4300 ADC to DUE .
it supposed to make RDY pin toggle at every 8uS once its registers set properly .
but the chip not responding at all .
i am sure my hardware connections are right . i attached my code and the signal from logic analyzer .
The chip ADC clock 1MHz is generated from Logic analyzer .
Connection diagram attached , code formatted . thanks.
here is my code :
#include <SPI.h>
// pins
#define PIN_RESET  9
#define PIN_DRDY  2
#define PIN_LED 13
#define SlaveSelectPIn 4
void resetAFE4300();
void writeRegister(unsigned char address, unsigned int data); //Writes to a register on the AFE4300
int readRegister(unsigned char address); //Reads from a register on the AFE4300
void initAFE4300(); //intialize AFE
void initWeighScale(); // Initializes the Weigh Scale Module
void initBCM(); // Initializes the BCM Module
int readData(); //  Reads the ADC data register
AFE4300 register address definitions
#define ADC_DATA_RESULT         0x00
#define ADC_CONTROL_REGISTER    0x01
#define MISC1_REGISTER          0x02
#define MISC2_REGISTER          0x03
#define DEVICE_CONTROL_1        0x09
#define ISW_MATRIX              0x0A
#define VSW_MATRIX              0x0B
#define IQ_MODE_ENABLE          0x0C
#define WEIGHT_SCALE_CONTROL    0x0D
#define BCM_DAC_FREQ            0x0E
#define DEVICE_CONTROL_2        0x0F
#define ADC_CONTROL_REGISTER_2  0x10
#define MISC3_REGISTER          0x1A
   pinMode(PIN_LED,   OUTPUT);
   pinMode(PIN_RESET, OUTPUT);
   pinMode(PIN_DRDY, INPUT);
   pinMode (PIN_CS, OUTPUT);
   Serial.flush();
   pinMode (13,OUTPUT);
   SPI.begin(SlaveSelectPIn); // SPI CS for slave
   SPI.setClockDivider(SlaveSelectPIn,42); // 2MHz SPI clock generation
   resetAFE4300();
   initAFE4300();
   initWeighScale();
      readData();
* @brief  Resets the AFE4300 device
void resetAFE4300()
       digitalWrite(PIN_RESET ,LOW);
       delay(100);
       digitalWrite(PIN_RESET ,HIGH);
* @brief  Writes to a register on the AFE4300
    unsigned char firstByte = (unsigned char)(data >> 8);
    unsigned char secondByte = (unsigned char)data;
   SPI.transfer(SlaveSelectPIn,address,SPI_CONTINUE);
   //Send 2 bytes to be written
   SPI.transfer(SlaveSelectPIn,firstByte,SPI_CONTINUE);
   SPI.transfer(SlaveSelectPIn,secondByte,SPI_LAST);
* @brief  Reads from a register on the AFE4300
         int spiReceive = 0;
         unsigned char spiReceiveFirst = 0;
         unsigned char spiReceiveSecond = 0;
         address = address & 0x1F; //Last 5 bits specify address
         address = address | 0x20; //First 3 bits need to be 001 for read opcode
         spiReceiveFirst  = SPI.transfer(SlaveSelectPIn,0x00,SPI_CONTINUE);
         spiReceiveSecond = SPI.transfer(SlaveSelectPIn,0x00,SPI_LAST);
          //Combine the two received bytes into a signed int
         spiReceive = (spiReceiveFirst << 8);
         spiReceive |= spiReceiveSecond;
         return spiReceive;
* @brief  Initializes the AFE4300 device
void initAFE4300()
           writeRegister(ADC_CONTROL_REGISTER,0x5140);
           writeRegister(MISC1_REGISTER,0x0000);
           writeRegister(MISC2_REGISTER,0xFFFF);
           writeRegister(DEVICE_CONTROL_1,0x0004); //Power down both signal chains
           writeRegister(ISW_MATRIX,0x0000);
           writeRegister(VSW_MATRIX,0x0000);
           writeRegister(IQ_MODE_ENABLE,0x0000);
           writeRegister(WEIGHT_SCALE_CONTROL,0x0000);
           writeRegister(BCM_DAC_FREQ,0x0040);
           writeRegister(DEVICE_CONTROL_2,0x0000);
           writeRegister(ADC_CONTROL_REGISTER_2,0x0011);
           writeRegister(MISC3_REGISTER,0x00C0);
* @brief  Initializes the Weigh Scale Module
   writeRegister(ADC_CONTROL_REGISTER,0x4120); //Differential measurement mode, 32 SPS
   writeRegister(DEVICE_CONTROL_1,0x0005); //Power up weigh scale signal chain
   writeRegister(ADC_CONTROL_REGISTER_2,0x0000); //ADC selects output of weigh scale
   writeRegister(WEIGHT_SCALE_CONTROL,0x003F); //Gain = 1 DAC Offset = -1
   writeRegister(BCM_DAC_FREQ,0x0040); //Frequency = default
   writeRegister(IQ_MODE_ENABLE,0x0000); //Disable IQ mode
   writeRegister(ISW_MATRIX,0x0000); //Channels IOUTP1 and IOUTN0
   writeRegister(VSW_MATRIX,0x0000); //Channels VSENSEP1 and VSENSEN0
* @brief  Initializes the BCM Module
void initBCM()
 writeRegister(DEVICE_CONTROL_1,0x0006);          //Power up BCM signal chain
 writeRegister(ISW_MATRIX,0x0804);                   //Channels IOUTP1 and IOUTN0
 writeRegister(VSW_MATRIX,0x0804);                  //Channels VSENSEP1 and VSENSEN0
 writeRegister(ADC_CONTROL_REGISTER_2,0x0063);   //ADC selects output of BCM-I output
 writeRegister(WEIGHT_SCALE_CONTROL,0x0000);     //Gain = 1 DAC Offset = 0
* @brief  Reads the ADC data register
int readData()
 return readRegister(ADC_DATA_RESULT);
Thanks in advance ,
-prag - INDIA
Duplicate thread in Due section deleted.
Please remember to use code tags when posting code.
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
an you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png?
Tom.... :slight_smile:
i modified with Code tags and connection diagram attached . thanks .
You might want to look into using the extended SPI library for the Due.
You're setting the speed to 2MHz, but the IC can only handle 1MHz.
You may need to set the proper data mode.
Mr . dlloyd , thanks a lot , i got the RDY working , i didn't set the SPI mode , once i set to MODE1 it is started working .
Actually the TI eval board they used 2MHz so i used it , the SPI clock not a issue . Thank you so much . i am standing upside down for a week , thanks .
final working code below .
#include <SPI.h>
// pins
#define PIN_RESET  9
#define PIN_DRDY   2
#define PIN_LED     13
    Serial.flush();
    SPI.setClockDivider(SlaveSelectPIn,42); // 2MHz clock generation
    SPI.setDataMode(SlaveSelectPIn, SPI_MODE1); // as Mr dlloyd  suggested . MODE 0 not working .
    resetAFE4300();
    initAFE4300();
    initWeighScale();
       readData();
void resetAFE4300()
        delay(100);
 int spiReceive = 0;
          return spiReceive;
void initAFE4300()
void initBCM()
int readData()
Moving back to Due section. Sorry.
Hello, can you help me, I want to activate the AFE4300 BCM, I have no way to do it, please help.
Hi wmarquinar ,
The AFE not throwing correct values for Body composition ( FAT mass ) ., we are also working on that i will keep you posted .
-prag
I'm testing the AFE4300 BCM, I use the AFE4300EVM-PDK (Development Guide), I use an RC circuit with two resistors 820 and 180 ohms and a capacitor 4 nF, I try to frequencies of 1, 4.16, 50, 100 and 250 KHz, with the following code, it works perfectly (I tried it with an oscilloscope), but I can't read the result of ADC_DATA_RESULT, I can't get the code to do so, you could help me with that ?.
thanks
the code is this
ARDUINO DUE:
#include <SPI.h>
// pins
#define PIN_RESET 9
#define PIN_DRDY 2
#define PIN_LED 13
void writeRegister(unsigned char address, unsigned int data); //Escribir en un registro del AFE4300
int readRegister(unsigned char address); //Leer desde el registro del AFE4300
void initAFE4300(); //Inicializar el AFE4300
//void initWeighScale(); // Initializes the Weigh Scale Module
//void initBCM(); // Initializes the BCM Module
int readData(); // Leer del ADC_DATA_RESULT
AFE4300 Definimos la direccion de los registros
Serial.flush();
SPI.begin(SlaveSelectPIn); // SPI CS para seleccionar el esclavo
SPI.setClockDivider(SlaveSelectPIn,21); // 2MHz clock generation
resetAFE4300();
initAFE4300();
//initWeighScale();
readData();
  • @brief Resets the AFE4300 device
    void resetAFE4300()
    delay(100);
  • @brief Writes to a register on the AFE4300
    unsigned char firstByte = (unsigned char)(data >> 8); //LA CARA ES UN OCHO)
  • @brief Reads from a register on the AFE4300
    int spiReceive = 0;
address = address & 0x1F; //Ultimos 5 bits especifican la direccion
address = address | 0x20; //Los primeros 3 bits tienen que ser 001 por código de operación de lectura
spiReceive = (spiReceiveFirst << 8); //LA CARA ES UN OCHO)
return spiReceive;
  • @brief Initializes the AFE4300 device
    void initAFE4300()
    writeRegister(ADC_CONTROL_REGISTER,0x4140);
    writeRegister(DEVICE_CONTROL_1,0x6006);
    writeRegister(BCM_DAC_FREQ,0x0010);
    writeRegister(MISC3_REGISTER,0x0030);
  • @brief Reads the ADC data register
    int readData()
ARDUINO UNO:
#include <SPI.h>
//#include "pins_arduino.h"
const int dataReadyPin = 8;
const int dataResetPin = 9;
const int slaveSelectPin = 10;
//void resetAFE4300()
// digitalWrite(dataResetPin ,LOW);
// delay(100);
// digitalWrite(dataResetPin ,HIGH);
SPI.begin();
SPI.setBitOrder(MSBFIRST); // Segun DATASHET
pinMode (slaveSelectPin, OUTPUT);
pinMode (dataReadyPin, INPUT);
//pinMode (dataResetPin, OUTPUT);
digitalWrite (MOSI, LOW);
digitalWrite (slaveSelectPin, HIGH);
SPI.setDataMode (SPI_MODE1);
SPI.setClockDivider(SPI_CLOCK_DIV16);
digitalWrite (slaveSelectPin, LOW);
//ADC_CONTROL_REGISTER1 0x00
SPI.transfer (0x00); //ponemos el bit 21 a '0' para escribir datos
SPI.transfer (0x00); //escribimos DATA el MSB [15...8]
SPI.transfer (0x00); //escribimos DATA el LSB [7...0]
//ADC_CONTROL_REGISTER1 0x01
SPI.transfer (0x01); //ponemos el bit 21 a '0' para escribir datos
SPI.transfer (0x41); //escribimos DATA el MSB [15...8]
SPI.transfer (0x40); //escribimos DATA el LSB [7...0]
//delay(10);
//MISC_REGISTER1 0x02
SPI.transfer (0x02); //ponemos el bit 21 a '0' para escribir datos
//delay(10);
//MISC_REGISTER2 0x03
SPI.transfer (0x03); //ponemos el bit 21 a '0' para escribir datos
SPI.transfer (0xFF); //escribimos DATA el MSB [15...8]
SPI.transfer (0xFF); //escribimos DATA el LSB [7...0]
//delay(10);
//DEVICE_CONTROL1 0x09
SPI.transfer (0x09); //ponemos el bit 21 a '0' para escribir datos
SPI.transfer (0x60); //escribimos DATA el MSB [15...8]
SPI.transfer (0x06); //escribimos DATA el LSB [7...0]
//delay(10);
//ISW_MUX 0x0A
SPI.transfer (0x0A); //ponemos el bit 21 a '0' para escribir datos
SPI.transfer (0x08); //escribimos DATA el MSB [15...8]
SPI.transfer (0x04); //escribimos DATA el LSB [7...0]
//delay(10);
//VSENSE_MUX 0x0B
SPI.transfer (0x0B); //ponemos el bit 21 a '0' para escribir datos
//delay(10);
//IQ_MODE_ENABLE 0x0C
SPI.transfer (0x0C); //ponemos el bit 21 a '0' para escribir datos
//delay(10);
//WEIGHT_SCALE_CONTROL 0x0D
SPI.transfer (0x0D); //ponemos el bit 21 a '0' para escribir datos
//delay(10);
//ADC_CONTROL_REGISTER2 0x10
SPI.transfer (0x10); //ponemos el bit 21 a '0' para escribir datos
SPI.transfer (0x63); //escribimos DATA el LSB [7...0]
//delay(10);
//MISC_REGISTER3 0x1A
SPI.transfer (0x1A); //ponemos el bit 21 a '0' para escribir datos
SPI.transfer (0x30); //escribimos DATA el LSB [7...0]
//delay(10);
//BCM_DAC_FREQ 0x0E
SPI.transfer (0x0E); //ponemos el bit 21 a '0' para escribir datos
SPI.transfer (0x01); //escribimos DATA el LSB [7...0]
//delay(10);
//LEER DATOS 0X20
// SPI.transfer (0x20); //ponemos el bit 21 a '1' para leer datos
// pinMode(MISO, INPUT);
// SPI.setDataMode (SPI_MODE0);
// byte MSB = SPI.transfer (0x20 >> 8); // LA CARA ES UN OCHO) enviamos 00 para leer dato MSB
// byte LSB = SPI.transfer (0x20); //enviamos 00 para leer dato LSB
// Serial.print(MSB, LSB);
digitalWrite (MOSI, HIGH);
SPI.end ();
I do not understand
address = address & 0x1F; // Last 5 bits specify the address
address = address | 0x20; // The first 3 bits have to be 001 per code reading operation
if only the bit 21 is to be put to one that is would be 0010 0000
I do not understand the 1F.
I got it, it works fine, thanks
Hi wmarquinar ,
Sorry for the late reply , in evaluation PDK board., the BCM values in FWR mode with calibration shows wrong values , i am comparing the FAT % with OMRON body FAT analyzer the values are differed a lot . 42% viscal FAT it shows when OMROM shows 23% , are you comparing with any standerd machine with PDK board ?
are you feeding age / gender information correct to the calculation ?
-ariesprg
