Tks for your reply Bob, the full path to the librairies is : D:\Arduino\sketchbook\libraries
This is not changed after installing W11, everything worked before on a 1.8 version.
I renamed the arch directory to prevend it from loading.
loading library from d:\Arduino\sketchbook\libraries\AdafruitTouchscreenControler: invalid library: no header files foundloading library from d:\Arduino\sketchbook\libraries\ArduinoApi: invalid library: no header files foundloading library from d:\Arduino\sketchbook\libraries\Fife_inch_TFT: invalid library: no header files foundloading library from d:\Arduino\sketchbook\libraries\SdFat: invalid library: no header files foundloading library from d:\Arduino\sketchbook\libraries\TFT5: invalid library: no header files found
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7
Using core 'esp32' from platform in folder: C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7
cmd /c if exist "D:\\Temp\\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\\sketch_mar8a\\partitions.csv" COPY /y "D:\\Temp\\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\\sketch_mar8a\\partitions.csv" "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\partitions.csv"
cmd /c if not exist "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\partitions.csv" if exist "C:\\Users\\rvdsc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.7\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\rvdsc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.7\\variants\\esp32\\partitions.csv" "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\partitions.csv"
cmd /c if not exist "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\partitions.csv" COPY "C:\\Users\\rvdsc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.7\\tools\\partitions\\default.csv" "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\partitions.csv"
cmd /c IF EXIST "D:\\Temp\\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\\sketch_mar8a\\bootloader.bin" ( COPY /y "D:\\Temp\\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\\sketch_mar8a\\bootloader.bin" "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\sketch_mar8a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\rvdsc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.7\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\rvdsc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.7\\variants\\esp32\\bootloader.bin" "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\sketch_mar8a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\rvdsc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\5.1.0\\esptool.exe" --chip esp32 elf2image --flash-mode dio --flash-freq 80m --flash-size 4MB -o "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\sketch_mar8a.ino.bootloader.bin" "C:\\Users\\rvdsc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.7\\bin\\bootloader_qio_80m.elf" ) )
esptool v5.1.0
Creating ESP32 image...
Merged 2 ELF sections.
Successfully created ESP32 image.
[cmd /c if exist "D:\\Temp\\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\\sketch_mar8a\\build_opt.h" COPY /y "D:\\Temp\\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\\sketch_mar8a\\build_opt.h" "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\build_opt.h"
PYI-1460:WARNING] Failed to remove temporary directory: D:\Temp\_MEI14602
cmd /c if not exist "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\build_opt.h" type nul > "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\build_opt.h"
cmd /c type nul > "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299/file_opts"
cmd /c COPY /y "C:\\Users\\rvdsc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.7\\sdkconfig" "C:\\Users\\rvdsc\\AppData\\Local\\arduino\\sketches\\FD6E715C3F862683439B8BF823FD6299\\sdkconfig"
1 fichier(s) copi�(s).
Detecting libraries used...
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299\sketch\sketch_mar8a.ino.cpp -o nul
Alternatives for WiFi.h: [WiFi@3.3.3 WiFi@3.3.7]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@3.3.3 WiFi@3.3.7]
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299\sketch\sketch_mar8a.ino.cpp -o nul
Alternatives for Network.h: [Networking@3.3.3 Networking@3.3.7]
ResolveLibrary(Network.h)
-> candidates: [Networking@3.3.3 Networking@3.3.7]
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299\sketch\sketch_mar8a.ino.cpp -o nul
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\AP.cpp
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\STA.cpp
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\WiFi.cpp
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\WiFiAP.cpp
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\WiFi\src\WiFiClient.cpp -o nul
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\WiFiGeneric.cpp
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\WiFiMulti.cpp
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\WiFiSTA.cpp
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\WiFiScan.cpp
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\WiFi\src\WiFiServer.cpp -o nul
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\WiFi\src\WiFiUdp.cpp -o nul
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\utility\server_drv.cpp
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\WiFi\src\utility\socket.c -o nul
Using cached library dependencies for file: d:\Arduino\sketchbook\libraries\WiFi\src\utility\spi_drv.cpp
Alternatives for SPI.h: [SPI@3.3.3 SPI@3.3.7]
ResolveLibrary(SPI.h)
-> candidates: [SPI@3.3.3 SPI@3.3.7]
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src -Id:\Arduino\sketchbook\libraries\SPI\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\WiFi\src\utility\wifi_drv.cpp -o nul
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src -Id:\Arduino\sketchbook\libraries\SPI\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\Network\src\NetworkClient.cpp -o nul
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src -Id:\Arduino\sketchbook\libraries\SPI\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\Network\src\NetworkEvents.cpp -o nul
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src -Id:\Arduino\sketchbook\libraries\SPI\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\Network\src\NetworkInterface.cpp -o nul
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src -Id:\Arduino\sketchbook\libraries\SPI\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\Network\src\NetworkManager.cpp -o nul
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src -Id:\Arduino\sketchbook\libraries\SPI\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\Network\src\NetworkServer.cpp -o nul
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src -Id:\Arduino\sketchbook\libraries\SPI\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\Network\src\NetworkUdp.cpp -o nul
C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2511/bin/xtensa-esp32-elf-g++ -c @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/defines -ID:\Temp\.arduinoIDE-unsaved202628-11272-14x4v5w.ybch\sketch_mar8a -iprefix C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/include/ @C:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/flags/includes -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.7/qio_qspi/include -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\cores\esp32 -IC:\Users\rvdsc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.7\variants\esp32 -Id:\Arduino\sketchbook\libraries\WiFi\src -Id:\Arduino\sketchbook\libraries\Network\src -Id:\Arduino\sketchbook\libraries\SPI\src @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/build_opt.h @C:\Users\rvdsc\AppData\Local\arduino\sketches\FD6E715C3F862683439B8BF823FD6299/file_opts d:\Arduino\sketchbook\libraries\SPI\src\SPI.cpp -o nul
'arch' folder is no longer supported! See http://goo.gl/gfFJzU for more information
Compilation error: 'arch' folder is no longer supported! See http://goo.gl/gfFJzU for more information
and after changing the nom of the arch directory :
esptool v5.1.0
