(took some time to think this over...)
Never used the EDB lib in a sketch so I am not influenced by any form of knowledge
If you want to be (99%) sure, the database must store metadata about the tables just like a real database. The eeprom is just the carrier of the bit with its specific properties like being fast etc.
In a real database there are (system)tables that describe the database, the users and their access rights and all kind of meta information (logging, performance monitoring data etc). Furthermore these system-tables describe which user-tables are in the database.
The edb doesnot log metadata in its database it just allocates a memory block. So to be sure you have the right table the creation of the table should at least write the name/type of record and optional its structure to some sort of systemtable. Such a systemtable could make life quite easier for the programmer.
proposal: edb++ lib
Suppose one has a system-table with the following record structure
{ char name[17], uint8_t recordsize, uint8_t, maxrecords, uint8_t #records, uint8_t startaddress } *
The first record in this table would be { "system", 20, 20, 1, 0 }
// this implies there is room in this database for 20 tables and this systemtable allocates 400 bytes.
The user could call
createTable("mytable", 40, sizeOf(struct xxx)); // name, max records, sizeof record
this would create an new entry in the systemtable // assume xxx uses 10 bytes
{ "mytable", 10, 40, 0, 400 }
Then the user could call
addRecord("myTable", currentrecord);
The user does not need to do the address administration as the lib has all the information to do so
Another function could be
boolean existTable(string); to test if the table you want to use exist in this eeprom. This call would solve your problem for 99%.
Other functions on this systemlevel would be: (not complete, just a braindump)
DATABASE-LEVEL
boolean createDatebase(#tables); // creates the system table --
boolean clearEEPROM(); // clears whole eeprom
SYSTEMLEVEL
boolean createTable(Tablename, maxRecords, recordSize);
boolean existTable(Tablename);
boolean wipeTable(TableName); // clears all entries (overwrites it);
boolean deleteTable(TableName); // removes entry from systemTable
int getRecordCount(TableName); // use "system" to get systemtable
int getMaxRecordCount(TableName);
int getRecordSize(TableName);
optional
boolean renameTable(TableName, newTablename);
boolean resizeTable(TableName, size); // optional as this one is
TABLE LEVEL
boolean addRecord(tablename, & var); // no need to add the address in eeprom or the size of the var as these are known!
boolean getRecord(tablename, index , &var);
boolean updateRecord(tablename, index, &var);
boolean deleteRecord(tablename, index);
The complexity of the functions above are not very high - especially if one allows fragmented memory. The added value is that if an Arduino would load a different sketch it could fetch only its tables from EEPROM without touching the others. Note that a table could also just have one record if one wants to store a config struct.
sofar my 2 cents
Rob
