Air Solenoid Valve "KSV05A - KOGE" - Arduino UNO
Hello everyone. :smiley: :smiley: :smiley:
I have a personal project with Arduino UNO and I need some help with some modules.
I need some information about the CODE and PINOUT of the following air solenoid valve.
The valve is: KSV05A Solenoid Valve - KOGE
I obtained it from a digital tensiometer just like this one.
D_NQ_NP_609347-MLA48209979162_112021-O
I got the datasheet of the valve but I can't find any information from someone who has tested it with Arduino UNO
KSV05A Solenoid Valve Datasheet
You will need a small transistor to turn the valve on/off
valve
Please, could you specify me with some sample images of what I need
1 BC547C transistor
1 680 ohm resistor
1 1N4004 diode
1 3.3V power supply
You can google to see images
Thank you very much for your contribution.
As for the PINOUT, is it as seen in the image?
Yes
Do you understand how to tead a schematic?
I'm not very familiar with the topic.
I understand how to read it anyway at least roughly
Well you started on a new adventure and have a lot of learning to do
Really, thanks for the help and willingness.
Now i need someone to help me a bit with the code
Well why don't you give it a try and see if you can make the LED turn off and on
I had the opportunity to try various projects such as making a servo work, turning an LED on and off, even with my brother we created a "teremin" with an ultrasonic sensor and a speake
Then you should have no trouble figuring this out.
Someone with information about how to code it on arduino?
Do you know how to write code that turns an LED on and off every second?
If so can you post your code here?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
