Alarm Clock Coding Display Issue
Hello, I am having trouble displaying the time and set alarm on my display. It is currently displaying the day and date. Is it something in my code? I am using an Arduino Uno.
:Project:Allarm_Clock
:Author: Tiziano Bianchettin
:Date: 10/02/2017
:Revision: 2
:License: Public Domain
thanks to:
  http://arduinoenonsolo.blogspot.it/2012/12/orologio-con-arduino-e-il-ds1307.html
  http://www.mauroalfieri.it/
  http://www.danielealberti.it/
  http://www.maffucci.it/
  My electronics laboratory professor "Perito Carli"
//************libraries**************//
#include <Wire.h>
#include <RTClib.h>
LiquidCrystal_I2C lcd(0x27,20,4); // Display  I2C 20 x 4
RTC_DS1307 RTC;
//************Button*****************//
int P1=6; // Button SET MENU'
int P2=7; // Button +
int P3=8; // Button -
int P4=9; // SWITCH Alarm
//**************Alarm***************//
#define LED 13
#define buzzer 10
//************Variables**************//
int hourupg;
int minupg;
int yearupg;
int monthupg;
int dayupg;
int menu =0;
int setAll =0;
uint8_t alarmHours = 0, alarmMinutes = 0;  // Holds the current alarm time
 lcd.init();
  lcd.backlight();
  lcd.clear();
  pinMode(P1,INPUT_PULLUP); // https://www.arduino.cc/en/Tutorial/InputPullupSerial
  pinMode(P2,INPUT_PULLUP);
  pinMode(P3,INPUT_PULLUP);
  pinMode(P4,INPUT_PULLUP);
  pinMode(LED,OUTPUT);
  pinMode(buzzer, OUTPUT); // Set buzzer as an output
  printAllOff();
  Wire.begin();
  RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // Set the date and time at compile time
    RTC.adjust(DateTime(F("5 / 21 / 2021"), F("7: 48")));;
  // RTC.adjust(DateTime(__DATE__, __TIME__)); //removing "//" to adjust the time
    // The default display shows the date and time
  int menu=0;
// check if you press the SET button and increase the menu index
  if(digitalRead(P1)== LOW)
   menu=menu+1;
  if((digitalRead(P2)== LOW)&&(digitalRead(P3)== LOW))
    DisplaySetHourAll();
    DisplaySetMinuteAll();
    lcd.clear();
    lcd.setCursor(5,0);
    lcd.print("ALARM");
    lcd.setCursor(5,1);
    lcd.print(alarmHours, DEC);
    lcd.print(":");
    lcd.print(alarmMinutes, DEC);
    lcd.clear();
// in which subroutine should we go?
  if (menu==0)
     DisplayDateTime(); // void DisplayDateTime
     Alarm(); // Alarm control
  if (menu==1)
    DisplaySetHour();
  if (menu==2)
    DisplaySetMinute();
  if (menu==3)
    DisplaySetYear();
  if (menu==4)
    DisplaySetMonth();
  if (menu==5)
    DisplaySetDay();
  if (menu==6)
    StoreAgg();
    menu=0;
    delay(100);
void DisplayDateTime ()
// We show the current date and time
  DateTime now = RTC.now();
  lcd.setCursor(0, 2);
  lcd.print("Hour : ");
  if (now.hour()<=9)
    lcd.print("0");
  lcd.print(now.hour(), DEC);
  hourupg=now.hour();
  lcd.print(":");
  if (now.minute()<=9)
    lcd.print("0");
  lcd.print(now.minute(), DEC);
  minupg=now.minute();
  lcd.print(":");
  if (now.second()<=9)
    lcd.print("0");
  lcd.print(now.second(), DEC);
  lcd.setCursor(0, 1);
  lcd.print("Date : ");
  if (now.day()<=9)
    lcd.print("0");
  lcd.print(now.day(), DEC);
  dayupg=now.day();
  lcd.print("/");
  if (now.month()<=9)
    lcd.print("0");
  lcd.print(now.month(), DEC);
  monthupg=now.month();
  lcd.print("/");
  lcd.print(now.year(), DEC);
  yearupg=now.year();
void DisplaySetHour()
// time setting
  lcd.clear();
  if(digitalRead(P2)==LOW)
    if(hourupg==23)
      hourupg=0;
      hourupg=hourupg+1;
   if(digitalRead(P3)==LOW)
    if(hourupg==0)
      hourupg=23;
      hourupg=hourupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set time:");
  lcd.setCursor(0,1);
  lcd.print(hourupg,DEC);
  delay(200);
void DisplaySetMinute()
// Setting the minutes
  lcd.clear();
    if (minupg==59)
      minupg=0;
      minupg=minupg+1;
    if (minupg==0)
      minupg=59;
      minupg=minupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set Minutes:");
  lcd.setCursor(0,1);
  lcd.print(minupg,DEC);
  delay(200);
void DisplaySetYear()
// setting the year
  lcd.clear();
    yearupg=yearupg+1;
    yearupg=yearupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set Year:");
  lcd.setCursor(0,1);
  lcd.print(yearupg,DEC);
  delay(200);
void DisplaySetMonth()
// Setting the month
  lcd.clear();
    if (monthupg==12)
      monthupg=1;
      monthupg=monthupg+1;
    if (monthupg==1)
      monthupg=12;
      monthupg=monthupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set Month:");
  lcd.setCursor(0,1);
  lcd.print(monthupg,DEC);
  delay(200);
void DisplaySetDay()
// Setting the day
  lcd.clear();
    if (dayupg==31)
      dayupg=1;
      dayupg=dayupg+1;
    if (dayupg==1)
      dayupg=31;
      dayupg=dayupg-1;
  lcd.setCursor(0,0);
  lcd.print("Set Day:");
  lcd.setCursor(0,1);
  lcd.print(dayupg,DEC);
  delay(200);
void StoreAgg()
// Variable saving
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("SAVING IN");
  lcd.setCursor(0,1);
  lcd.print("PROGRESS");
  RTC.adjust(DateTime(yearupg,monthupg,dayupg,hourupg,minupg,0));
  delay(200);
void DisplaySetHourAll()// Setting the alarm minutes
  while(digitalRead(P1)==HIGH){
  lcd.clear();
    if(alarmHours==23)
      alarmHours=0;
      alarmHours=alarmHours+1;
    if(alarmHours==0)
      alarmHours=23;
      alarmHours=alarmHours-1;
  lcd.setCursor(0,0);
  lcd.print("Set HOUR Alarm:");
  lcd.setCursor(0,1);
  lcd.print(alarmHours,DEC);
  delay(200);
 delay(200);
void DisplaySetMinuteAll()// Setting the alarm minutes
  lcd.clear();
    if (alarmMinutes==59)
      alarmMinutes=0;
      alarmMinutes=alarmMinutes+1;
    if (alarmMinutes==0)
      alarmMinutes=59;
      alarmMinutes=alarmMinutes-1;
  lcd.setCursor(0,0);
  lcd.print("Set MIN. Alarm:");
  lcd.setCursor(0,1);
  lcd.print(alarmMinutes,DEC);
  delay(200);
 delay(200);
void printAllOn(){
   lcd.setCursor(0,3);
  lcd.print("Alarm: ");
  if (alarmHours <= 9)
    lcd.print("0");
  lcd.print(":");
  if (alarmMinutes <= 9)
    lcd.print("0");
void printAllOff() {
  lcd.setCursor(0, 3);
  lcd.print("Alarm: Off  ");
void Alarm(){
   if(digitalRead(P4)== LOW)
   setAll=setAll+1;
  if (setAll==0)
     printAllOff();
     noTone (buzzer);
     digitalWrite(LED,LOW);
  if (setAll==1)
     printAllOn();
     if ( now.hour() == alarmHours && now.minute() == alarmMinutes )
         lcd.noBacklight();
         digitalWrite(LED,HIGH);
         tone(buzzer,880); //play the note "A5" (LA5)
         delay (300);
         tone(buzzer,698); //play the note "F6" (FA5)
         lcd.backlight();
    else{
         noTone (buzzer);
  if (setAll==2)
     setAll=0;
    delay(200);
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
My bad, I didn't know which type of forum my question should of went under because its a little bit of both. Both has issues with the display and with the coding.
Does it work if you press P2 & P3?
