#include <LiquidCrystal.h> // includes the LiquidCrystal Library
#include <math.h> //para el redondeo
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); // Creates an LCD object. Parameters: (rs, enable, d4, d5, d6, d7)
// Connect panel using the standard lines.
// Sensor 1, trigger pin 13 y echo pin 12.
const int trigPin1 = 13;
const int echoPin1 = 12;
// Sensor 2, trigger pin 11 y echo pin 10.
const int trigPin2 = 11;
const int echoPin2 = 10;
// dimensiones Tanque 1 (el que esta en la parte inferior) en metros.
const float lengthBottomTankM = 3.2;
const float widthBottomTankM = 2;
const float deepBottomTankM = 1.7;
const float volTotalBottomTankM3 = 8.96; // Restado 0.3 de distancia al sensor tanque inferior
// dimensiones Tanque 2 (el que esta en la parte inferior) en mestros
const float lengthUpTankM = 2.74;
const float widthUpTankM = 2;
const float deepUpTankM = 1.9;
const float volTotalUpTankM3 = 9.32; // Restado 0.2 de distancia al sensor tanque superior
long duration1;
float deepBottomTankCm;
long duration2;
float deepUpTankCm;
float volumeBottomTank;
float volumeUpTank;
float porcBottomTank;
float porcUpTank;
lcd.begin(16,2); // Initializes the interface to the LCD screen, and specifies the dimensions (width and height) of the display
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
Serial.begin (9600);
// Trigger Lower tank
digitalWrite(trigPin1, LOW);
delayMicroseconds(2);
digitalWrite(trigPin1, HIGH);
delayMicroseconds(10);
duration1 = pulseIn(echoPin1, HIGH);
deepBottomTankCm= duration1*0.034/2;
// Trigger upper tank
digitalWrite(trigPin2, LOW);
digitalWrite(trigPin2, HIGH);
duration2 = pulseIn(echoPin2, HIGH);
deepUpTankCm= duration2*0.034/2;
if (deepBottomTankCm > 0 && deepUpTankCm > 0) {
// Make calculations based on volume1 and volume2
volumeBottomTank = lengthBottomTankM * widthBottomTankM * (deepBottomTankM - (float)deepBottomTankCm/100);
porcBottomTank = (float)volumeBottomTank/(float)volTotalBottomTankM3 * 100;
volumeBottomTank = round(volumeBottomTank*10);
volumeBottomTank = volumeBottomTank/10;
volumeUpTank = lengthUpTankM * widthUpTankM * (deepUpTankM - (float)deepUpTankCm/100);
volumeUpTank = round(volumeUpTank*10);
volumeUpTank = volumeUpTank/10;
porcUpTank = (float)volumeUpTank / volTotalUpTankM3 * 100;
Serial.println("cmBottom," + String(deepBottomTankCm) + ";
cmUp," + String(deepUpTankCm));
// Show information on LCD
lcd.setCursor(0,0); // Sets the location at which subsequent text written to the LCD will be displayed
lcd.println("S: " + String(volumeUpTank) + "m3, "+ String(round(porcUpTank)) + "% "); // Prints string "Distance" on the LCD
lcd.println("DistaCm: " + String(deepUpTankCm) + " ");
delay(10);
lcd.setCursor(0,1);
lcd.println("I: " + String(volumeBottomTank) + "m3, "+ String(round(porcBottomTank)) + "% ");
lcd.println("DistCm: " + String(deepBottomTankCm) + " ");
