I just bought my Arduino Uno a couple months ago (new to prototyping), and for some reason it started outputting voltages wayy lower than 5 volts. While I cannot give you the exact number (buying a multimeter tomorrow), when I uploaded a blink sketch the led was barely visible (using a 220 ohm resistor, the one recommended by the LED manufacturer). The 5v pin is still performing nominally, so I doubt that there is a problem with the voltage regulator. Keep in mind I am getting power from my PC directly via USB connection.
If anyone has any advice let me know
P.S. Here is a basic test sketch I've been using. There also doesn't seem to be an issue with the analog pins and as far as I can tell, there is no external damage to the board.
const int LED = 5;
digitalWrite(LED, OUTPUT);
digitalWrite(LED, HIGH);
