Hi guys I made a draft of the code that's going to set the time and date the alarm of my arduino directly from the buttons. Below place the sketch if someone could give us a look at the beginner again and surely there will be errorini.
Thanks in advance
#include <Wire.h>
#include <RTClib.h>
#include <LiquidCrystal.h>
#define RELAY_PIN 2 // PIN definitions
#define BACKLIGHT 2
#define CONTRAST 3
#define SET A0
#define PIU A1
#define MENO A2
#define STATE_OFF 0 //FSM states
#define STATE_ON 1 //FSM states
int fsm_state;
char buffer[10];
unsigned long time=0;
unsigned long timeSet=0;
int setModeTime=3000;
RTC_DS1307 RTC;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup () {
pinMode( BACKLIGHT, OUTPUT );
pinMode( CONTRAST, OUTPUT );
digitalWrite( BACKLIGHT, HIGH );
analogWrite( CONTRAST, 40 );
pinMode(RELAY_PIN, OUTPUT);
digitalWrite(RELAY_PIN, LOW);
fsm_state = STATE_OFF;
Wire.begin();
RTC.begin();
lcd.begin(16, 2);
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
RTC.adjust(DateTime(__DATE__, __TIME__));
pinMode( SET, INPUT );
pinMode( PIU, INPUT );
pinMode( MENO, INPUT );
void loop () {
if ( analogRead( SET ) < 1000) { time = millis(); }
DateTime now = RTC.now();
int nowHourMinute = now.hour() * 100 + now.minute();
sprintf(buffer, "%02d/%02d/%d", now.day(), now.month(), now.year());
lcd.setCursor(0,0);
lcd.print( buffer );
char buffer[10] = "";
sprintf(buffer, "%02d:%02d:%02d", now.hour(), now.minute(), now.second());
lcd.setCursor(0,1);
char buffer_allarm[10] = "";
lcd.setCursor(0,3);
lcd.print( buffer_allarm );
if (time > 0 && setModeTime < (millis() - time) ) { setMode( now ); }
void setMode( DateTime now ) {
boolean setMode = true;
int setModeLevel = 0;
int _day = now.day();
int _month = now.month();
int _year = now.year();
int _hour = now.hour();
int _min = now.minute();
int _sec = now.second();
int _hourallarm = now.hour();
int _minuteallarm = now.minute();
int _secallarm = now.second();
lcd.clear();
lcd.setCursor(0,0);
sprintf(buffer, "%s: %02d", "Giorno", _day);
delay( 1000 );
timeSet = millis();
while ( setMode ) {
if ( analogRead(SET) > 1000 || analogRead(PIU) > 1000 || analogRead(MENO) > 1000 ) { timeSet = millis(); }
lcd.setCursor(0,0);
// Set Day
if ( setModeLevel == 0 ) {
if ( analogRead(PIU) > 1000 && _day < 31) { _day++; }
if ( analogRead(MENO) > 1000 && _day > 1) { _day--; }
// Set Month
if ( setModeLevel == 1 ) {
if ( analogRead(PIU) > 1000 && _month < 12) { _month++; }
if ( analogRead(MENO) > 1000 && _month > 1) { _month--; }
sprintf(buffer, "%s: %02d", "Mese", _month);
// Set Year
if ( setModeLevel == 2 ) {
if ( analogRead(PIU) > 1000 && _year < 9999) { _year++; }
if ( analogRead(MENO) > 1000 && _year > 1900) { _year--; }
sprintf(buffer, "%s: %02d", "Anno", _year);
// Set Hour
if ( setModeLevel == 3 ) {
if ( analogRead(PIU) > 1000 && _hour < 24) { _hour++; }
if ( analogRead(MENO) > 1000 && _hour > 1) { _hour--; }
sprintf(buffer, "%s: %02d", "Ora", _hour);
// Set Minute
if ( setModeLevel == 4 ) {
if ( analogRead(PIU) > 1000 && _min < 60) { _min++; }
if ( analogRead(MENO) > 1000 && _min > 1) { _min--; }
sprintf(buffer, "%s: %02d", "Minuti", _min);
// Set Second
if ( setModeLevel == 5 ) {
if ( analogRead(PIU) > 1000 && _sec < 60) { _sec++; }
if ( analogRead(MENO) > 1000 && _sec > 0) { _sec--; }
sprintf(buffer, "%s: %02d", "Secondi", _sec);
// Set Hour
if ( setModeLevel == 6 ) {
sprintf(buffer, "%s: %02d", "Ora", _hourallarm);
// Set Minute
if ( setModeLevel == 7 ) {
sprintf(buffer, "%s: %02d", "Minuti", _minuteallarm);
// Set Second
if ( setModeLevel == 8 ) {
sprintf(buffer, "%s: %02d", "Secondi", _secallarm);
if ( analogRead(SET) > 1000 ) { lcd.clear(); setModeLevel++; }
if ( setModeLevel > 8 ) { setModeLevel=0; }
if (timeSet > 0 && (setModeTime*2) < (millis() - timeSet) ) {
RTC.adjust(DateTime(_year, _month, _day, _hour, _min, _sec));
setMode = false;
delay(200);
RTC.adjust(DateTime(_hourallarm, _minuteallarm, _secallarm));
setMode = false;
delay(200);
set_timer_allarm.ino (5.22 KB)
