The SoftwareSerial.h lib isn't working for my needs so I switched to the AltSoftSerial lib. That one seems to work for what I am doing. However I already have a handful of boards that have pins 4 and 5 of the Ardunio Pro Mini configured and connected to a STRS232 (RS-232 12v level to 5v level) as pin 4 RX and pin 5 TX.
The AltSoftSerial specifies pins 8 and 9 respectively must be used for a Pro mini (same as UNO). I can solder a jumper from pin 4 to 8 and from pin 5 to 9 but I would much rather - if possible - change the lib so pins 4 and 5 can be used instead.
Is this fairly simple to do or are pins 8 and 9 used for a specific reason and other pins may not work, and is why they can not be changed?
It's not clear to me, how you could have RX and TX on pins 4 and 5 of the pro mini. RX and TX are two pins near the corner of the board and they don't have any number.
michinyon:
For the Hardware serial yes, but Software Serial lets you use any digital pin (well almost any) for a extra serial port. As stated, I am useing the Hardware Serial (Pins TX ad RX) already so I need a second serial port, therefore the reason for the AltSoftSerial.
