Always get -1 connection refused response from server
I am new to arduino and programing . .. I am making a alert device on my node mcu board to report any orders made by customers on my application. The nodemcu should access the network using wifi and call the rest api. I tried researching many sites and modified the code several times, but the response is always -1, connection refused . ..the issue is same for my server or any other rest api example.
It only worked once during its first run . .. never after that . .
tried doing
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
ESP8266WiFiMulti WiFiMulti;
// Serial.setDebugOutput(true);
for (uint8_t t = 4; t > 0; t--) {
Serial.printf("[SETUP] WAIT %d...\n", t);
Serial.flush();
WiFi.mode(WIFI_STA);
WiFiMulti.addAP("----", "----");
// wait for WiFi connection
if ((WiFiMulti.run() == WL_CONNECTED)) {
WiFiClient client;
HTTPClient http;
Serial.print("[HTTP] begin...\n");
if (http.begin(client, "http://34.87.116.113:80/api/v1/iot/Notify/poll")) { // HTTP
http.setAuthorization("admin", "admin123!");
Serial.print("[HTTP] GET...\n");
// start connection and send HTTP header
int httpCode = http.GET();
// httpCode will be negative on error
if (httpCode > 0) {
// HTTP header has been send and Server response header has been handled
Serial.printf("[HTTP] GET... code: %d\n", httpCode);
// file found at server
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
String payload = http.getString();
Serial.println(payload);
Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
Serial.printf("[HTTP} Unable to connect\n");
delay(5000);
First: edit your post and insert code tags!
Really? Exactly that result? In that case you didn't load above code.
Most probably your device doesn't have a filter-free network connection to that server.
The IP address you connect to is in a Google range. I doubt that Google offers services that are accessible by it's IPv4 address.
