I'm simply trying to drive a SFH409 GAAS T1 Emitter from the 5v rail on the arduino which is powered from a 9v dc supply
I've put a 47ohm resistor between the 5v and the ir emitter to limit the current to under 100mA but for some reason the ir phototransistor (SFH309) just isn't responding to ir. I've checked the phototransistor is working ok and the emitter and phototransistor are only 1cm apart.
sorry I was being ambiguous. The 309 phototransistor responds to ir using an alternative ir source but not when pointed at the 409 emitter so I am assuming the 409 isn't functioning. The 409 is connected correctly but I did recheck it ,
I am assuming a Vf of 1.3v so the 47ohm should be limiting the current to around 80mA, is this sufficent to drive the emitter?
The 309 is being used in a simple voltage divider circuit with a 300k resistor in series and I'm picking off the voltage between them and feeding it to an analogue input pin (5v = beam is blocked, something less than 5v beam is not blocked, probably around 2 volts)
