Hello
my Code
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
const int sensorPin = A0; // Normal Temp MP36 / 36gz Chip
#define DHTPIN 7 // what pin we're connected to
#include "DHT.h"
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
Serial.println("DHTxx test!");
dht.begin();
int sensorVal = analogRead(sensorPin);
Serial.print("TMP36 / 36gz Chip: --> " );
Serial.print("Sensor Value: ");
Serial.print(sensorVal);
float voltage = (sensorVal/1024.0) * 5.0;
Serial.print(", Volts: ");
Serial.print(voltage);
Serial.print(", degrees C: ");
float temperature = (voltage - .5) * 100;
Serial.println(temperature);
// Serial.print("hallo askim, off es ist " );
// Serial.print(temperature);
// Serial.println(" C, warm!!!");
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
delay(60);
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t) || isnan(h))
Serial.println("Failed to read from DHT");
{ Serial.print("AM2302 DHT22 Chip: --> " );
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.println(" *C");
Serial.print("Temperatur Differenz: ");
Serial.print(t - temperature);
Serial.println(" Grad");
Serial.print("Durchscnittliche Temperatur: ");
Serial.print( (t + temperature)/2);
Serial.println(" Grad Celsius");
Serial.println("================================");
delay(24000);
so i got a output like
17:34:01.710 -> Failed to read from DHT
17:34:01.743 -> TMP36 / 36gz Chip: --> Sensor Value: 160, Volts: 0.78, degrees C: 28.12
17:34:01.843 -> Failed to read from DHT
17:34:01.843 -> TMP36 / 36gz Chip: --> Sensor Value: 159, Volts: 0.78, degrees C: 27.64
and then it reads the Sensordata and all works fine.
so when reading the dht data it is not possible to wait until they are there.
around line 52 i added a delay(60) but did not seems to work
have e nice day
vinc
