Hi everyone, first post for me into this forum and new too, to Arduino. I'm using a AM2302 humidity/temperature sensor and the arduino library with DHT tester example supply with it: GitHub - adafruit/DHT-sensor-library: Arduino library for DHT11, DHT22, etc Temperature & Humidity Sensors
Tha'st work fine, I can see thru the monitor the Temp. & Humidity numbers. My problem is I what to add on this tester things like:
If Temperature is greater than 20°C, turn on outputpin 8 HIGH(fans),else LOW! Same thing for humidity, If less than 50% turn on outputpin9 HIGH(humidifier)else LOW. Which variable to take or to create? I don't understand what is the variable to read and use, and after to manipulate it, and to do something whith it, when you using the library!
Code DHT Tester:
/ Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 2 // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
Serial.println("DHTxx test!");
dht.begin();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t) || isnan(h)) {
Serial.println("Failed to read from DHT");
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.println(" *C");
Thank's in advance
