Hello All,
I am looking for a bit of assistance to get my microcontroller to fall asleep and wake-up due to an interrupt from the analog comparator. The idea here is that I have an accelerometer connected to an analog input PD6 (AIN0) D6 and a reference voltage on PD7 (AIN1) D7. This way when the device is moved it will wake-up.
I have started with a example program from Nick Gammon. I tested using the ISR to blink the LED as the accelerometer value rises over the threshold of D7 (1.5V).
I have been looking at some of the examples programs for putting the Arduino to sleep.
Here is a snapshot of my code.
* Date: 2/15/16
* Example Sleep Program using the Analog Compator
* Originally based on Nick Gammon's Analog Sleep Comparator Program
* Atmel328p processor with accelerometer connected to PD6 (AIN0), Digital Pin 6 on Arduino IDE
* Pin PD7 (AIN1), Digital Pin 7 on Arduino IDE, has a voltage divider set to 1.5 V.
#include <avr/interrupt.h>
#include <avr/power.h>
#include <avr/sleep.h>
#include <avr/io.h>
int ledPin = 4;
volatile boolean triggered;
void setup(void)
pinMode(ledPin,OUTPUT); // set LED pin (D4) as an output
digitalWrite(ledPin,LOW); // turn LED on (active low)
ADCSRB = 0; // (Disable) ACME: Analog Comparator Multiplexer Enable
ACSR = bit (ACI) // (Clear) Analog Comparator Interrupt Flag
| bit (ACIE) // Analog Comparator Interrupt Enable
| bit (ACIS1); // ACIS1, ACIS0: Analog Comparator Interrupt Mode Select (trigger on falling edge)
triggered = 0;
void loop(void)
if (triggered == true)
delay(3000); // wait to see the LED before sleeping again
sleepNow();
void sleepNow(void)
triggered = false;
digitalWrite(ledPin,HIGH); // turn LED off (active low)
// Choose our preferred sleep mode:
set_sleep_mode(SLEEP_MODE_IDLE);
// Set sleep enable (SE) bit:
sleep_enable();
// Put the device to sleep:
sleep_mode();
// Upon waking up, sketch continues from this point.
sleep_disable();
ISR (ANALOG_COMP_vect)
triggered = true;
Any help will be much appreciated. The goal here is to improve the battery life for this project.
Thanks,
NB
