Analog input value
I made my own wearable flexible sensor (flexible resistor) but I connected a 10k (1M)resistor and 5v and wanted to take a reading of the resistance of this resistor but the arduino analog inputs are like floating pins but the connection is correct
does anyone fix this problem before?
  • Always show us a good schematic of your proposed circuit.
    Show us good images of your ‘actual’ wiring.
    Give links to components.
sorry it was my first question,there are coding and circuit.
Hint: The A/D works best with an input impedance of 10K or less. If you must use a higher resistance, you should add a capacitor to the input pin of the A/D for better performance.
i saw this hint in other's problem, so i change res from 1m to 10k.shall i add a capacitor after i have already changed the res?
Do you have 2 homemade resistors?
The values in your printout move together. Which makes me think your vcc is not stable.
How do you power your setup?
What else is connected?
my power(5v) came from arduino,i use a expand board with uno r3.
but several weeks ago,they were working well.
This setup will pick up emi.
Keep wires to and from sensors together.
Add a 100 nF cap near your analog input.
put a 100nf cap between analog input and gnd?
Hi @gilshultz, I'm trying to dispel that "10k" nonsense.
Here is the input to the ADC
I dont know if you have seen the results of my tests with a 500M resistor that show the "10k" is only relevant if you are measuring signals that change VERY fast.
and the results of my test with a step wave. The x axis is 1 unit = 20 usec.
The Y axis is raw ADC value (the step wave from the D6 output is attenuated so the max ADC reading is a bit less than 1024)
of course on a breadboard with a 500M resistor and unscreened its subject to interference.
I'd suspect the resistors, the connections or (since we havent been shown it) the code.
The cap will probably help stabilize the reading.
I'm on your side John.
I frequently use a 1MΩ resistor from an analogue input to GND, so that I can use it with a X10 oscilloscope probe.
It works well.
Maybe that white goop in the plastic bag has dried out.
Yep, between analog input and gnd.
To be honest, I do not understand this whole issue about resistors if 10k or 500M. The resistor should be around the same value as the 'sensor' resistor...
hi my own res can change from several k to several m ohms,so i just try which range res can work better. i try the method u provide, it s still not work.
hi@ jim-p,the thing u said is my
own flexible res.
Hi, @fanfanfan99
Welcome to the forum.
This link will show you how to post your code.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
If you test with an ohmmeter does it still work?
@fanfanfan99 Is there a language issue here? By "own flexible res", are you really saying "my own variable res", referring to the resistance of your body?
