Hello,
I was getting a huge variation in my voltage measurement value, hence I wanted to look after the ADC value (1023 usually) and the VCC (5 V usually) and calibrate accordingly to the values, to get correct sensor voltage measurements.
On measuring the VCC value, I got it to be around 5.03V and I plugged the analogread to the pin in order to see the adc value it is generating for the full-scale VCC value(based on which, I will be changing in the code)
But as and when I read the raw analog value, I noticed it was fluctuating. I have even attached screenshot regarding that. Initially, my adc value read 1022(I don't have the screenshots for it), but later I got a reading of 989 and kept fluctuating to 999 and then 991, I just continue further, but I am sure this fluctuation occurs for a long range of values.
Can someone sort out on why my analogread values are fluctuating??
