I tried reading analog input for a switch.But the analog value is moving gradually from 0 to 1023 and back to 0 ,eventhough the switch is not pressed.
When switch is pressed,it reaches 1023.This is agreeable.
But when switch is not pressed,it reaches 1023.Please help me to resolve the issue.This will solve my other issue automatically…
I am using 20K ohm resistor.
#include <SPI.h>
#include <PubSubClient.h>
#include <Ethernet.h>
#include <util.h>
#include <ctype.h>
#define CLIENTID “ArduinoSensor”
#define TOPICNAME “switch/signal”
#define POLLINTERVAL 120000
#define PORT 80
//Connect to MQTT server
byte server1 = { X};
byte mac = {X};
IPAddress arduinoIP(X);
IPAddress dnsIP(X);
IPAddress gatewayIP(X);
IPAddress subnetIP(X);
EthernetServer server(PORT);
EthernetClient ethClient;
PubSubClient arduinoClient(server1, 8081, callback, ethClient);
void callback(char* topic, byte* payload, unsigned int length) {
// handle message arrived
int analogPin = 0; // potentiometer wiper (middle terminal) connected to analog pin 3
// outside leads to ground and +5V
int val = 0; // variable to store the value read
Serial.begin(9600); // setup serial
Ethernet.begin(mac, arduinoIP, dnsIP, gatewayIP, subnetIP);
beginConnection() ;
void beginConnection() {
//Ethernet.begin(mac) ;
int connRC = arduinoClient.connect(CLIENTID) ;
if (!connRC) {
Serial.println(connRC) ;
Serial.println(“Could not connect to MQTT Server”);
Serial.println(“Please reset the arduino to try again”);
delay(100);
exit(-1);
else {
Serial.println(“Connected to MQTT Server…”);
val = analogRead(analogPin); // read the input pin
Serial.println(val);
delay(100); // debug value
if(val == 1023)
Serial.println(“Button pressed and message published”);
arduinoClient.publish(TOPICNAME, “Button A is Pressed”) ;
Its working better…But I see a problem with the analogRead…
The readings goes as below,
0
0
0
0
19
20
49
71
117
126
227
322
451
571
702
809
923
1023
1023
1023
1022
1003
966
929
905
842
748
615
480
356
229
122
1
0
0
0
0
0
0
The readings gradually increasing till 1023 and then decreasing gradually.This should not happen as it is publishing messages when it is reaching 1023 without even pressing the switch.
But When the switch is pressed,it reaches 1023 and publishing the message.This is fine as this is required scenario…
Can you please help how to control the flow of analogRead?If this is kept under control,then my problem would be resolved…
