Analog Read and processing of voltage quite a bit slower on Every vs Classic Nano, here's the code
I have written a simple filter function to lowpass filter on voltage. I noticed it was running slower on the nano every vs the regular nano, in either native 4809 or emulated ATMEGA328. I don't think it's a code issue as the code is identical and loaded on both, but someone here may point out how to optimize it better or that I've done something wrong... I have an unfiltered analog read on pin A6 to take voltage. Then I print that to a display, and pass the value into two filters for additional output. All the outputs to the display differ in speed between the two boards, though they shouldn't. I have the boards both powered from the same source, and both getting a feed from the same battery in parallel to measure. Current and voltage supply is not a problem. I am using a pot to adjust the voltage for testing to both boards simultaneously.
Voltage read is fluctuating on the nano every up and down, a tenth or so, in a slow sine wave like fashion, and that same input voltage is completely locked and stable on the classic nano. That's the first issue.
The second is I don't think that SPI is working correctly on the Every, as it is very slow in both processor modes. The updates to the screen trail the classic by quite a bit regarding the first and second filtered outputs. And the raw read output is very choppy as it passes through its range on the every.
Here's the code:
//Arduino Nano vs Nano Every comparison with identical code
#include <Adafruit_SSD1331.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
//********************NANO OLED DEFINITIONS for use when uploading NANO Code
#define SCL 13
#define SDA 11
#define CS   10
#define RST  9
#define DC   8
//_______________________________________
#define VOLTPIN A6
// ---------------------------------------------Display Initializers
// -----------------------------------------------Color definitions
#define YELLOW          0xFFE0
#define BLACK           0x0000
//Adafruit_SSD1331 display = Adafruit_SSD1331(CS, DC,SDA, SCL, RST); // for non -spi on worse boards
Adafruit_SSD1331 display = Adafruit_SSD1331(&SPI, CS, DC, RST);
//SPISettings settingsA(2000000, MSBFIRST, SPI_MODE1);  // use lower MB values for worse boards to reduce impedance issues
char voltage_str [4] = "";
float batteryVoltageInput = 0;
float voltageFilter (float rawValue, byte factor) {
static float filteredVal1 = 0, filteredVal2 = 0;
  if (factor ==1) {
  filteredVal1 =  0.80  *filteredVal1 + 0.20 * rawValue;
  return filteredVal1;
    filteredVal2 =  0.946*filteredVal2 + 0.054 * rawValue;
    return filteredVal2;
 pinMode(10, OUTPUT);
 pinMode(VOLTPIN, INPUT);
// analogRead(INTERNAL4V3); // Try to see if better next?
 SPI.begin();
 display.begin();                                      // initialize with the I2C addr 0x3D (for the 128x64)
 display.fillScreen(BLACK);
delay(200);
    display.setTextSize(1);
    display.setTextColor(YELLOW,BLACK);
// ------------------------------------------------- V O I D    L O O P ------------------------------------------
static float filtered_voltage = 0;
batteryVoltageInput = (float)analogRead(VOLTPIN)*5/1023; // Read the raw analog value and convert it
    dtostrf(batteryVoltageInput,4,2,voltage_str);
    display.setCursor(0,8);
    display.write(voltage_str);  //unfiltered voltage
   filtered_voltage = voltageFilter(batteryVoltageInput,1);
    dtostrf(filtered_voltage,4,2,voltage_str);
    display.setCursor(0,22);
    display.write(voltage_str);  //filtered with first filter function
   filtered_voltage = voltageFilter(batteryVoltageInput,2);
    display.setCursor(0,33);
    display.write(voltage_str);  //Filtered with 2nd filter function
The output is to an oled with 1331 driver.
Draw a schematic, draw a wiring diagram
Don't have a way to really do that right now, but it was connected as follows: Both nano and every have this pinout hardwired to each of their own displays from their pins.
SCL 13 to SCL on display
SDA 11 to SDA on display
CS 10 to CS on display
RST 9 to RES on display
DC 8 to DC on display
+5v pin to display VCC
GND pin to Display Gnd
+4.5v to A6 on Every, (RED) + 4.5v to A6 on Classic (RED)
GND to GND
VIN to +8v on Classic (RED) and GND to GND
VIN to +8v supply on Every (RED) and GND to GND.
Doesn't get much easier than that..
Looks like there's an open issue here
