Analog read problems
I will begin by saying I am new to arduino. I bought a shield for photography (Loading...). It work fine for about a day then the buttons stopped working. The buttons are wired in series to resistors so that 5 buttons would create 5 different analog values for one analog input. I began reading the basic tutorial for beginners and did a analogRead() and Serial.println(). The serial monitor show a constant stream of 1023. This is the same with all of the analog pins. I plugged a 10k pot and it still doesn't change. Is the chip or board broken or and I doing something wrong?
Thanks,
Matt
What is the code you are using? What happens if you use a different analog input?
Remove the shield.
Connect the analog input to GND. Do you get a rock-solid zero from analogRead?
Connect the analog input to +5 V. Do you get a rock-solid 1023 from analogRead?
I am using the code from http://arduino.cc/en/Tutorial/AnalogReadSerial
When I connect the analog input into GND, it still reads 1023.
What about analog input 1? What does it read when connect to GND?
I have tried connect all of the analog ports to ground and they all read 1023.
If the chip is socketed, try re-seating it.
Are you sure you connected it to ground?
Maybe the ADC happened to die due to bad luck?
I tried reseating the chip.
I tried connecting the analog to all of the GND pins on the board.
If it is an ADC problem, do I have to replace the chip or the board? Are there ways to to be certain that the ADC is the source of the problem?
Are you using the ports on the side with the 9V input socket? And what board are you using?
I have an arduino duemilanove.
On this reference picture, http://www.satistronics.com/arduino-duemilanove-2009-pcb-board_p2765.html , I have a connector between GND below the power pins, and 0 below the Analog IN pins.
What analog readings do you get with nothing connected?
Are you using version 0022 of the IDE?
I am using 022 and I always get 1023, unplugged or not.
If this...
...is really what you're using for testing then I'm afraid the only thing left is a damaged A/D converter. If that is the only problem (and it sounds as though it is), you can replace the processor. Be sure to get one with a bootloader (or be prepared to install a bootloader).
So I just need to replace the Atmega chip and not the board. Correct?
Yes.
It has to have a bootloader though.
Ok. Thanks for all of the help.
