analogWrite from an ir code IF comparison match
Reading ir codes from a remote, I need to execute an analogWrite when a match occurs. I've tested analogWrite separately from an IF statement and that seems to work. But when I put it in an ir reader comparison, analogWrite doesn't write anything. The ir read loop works fine, it just ignores the analogWrite command.
A digitalWrite however, does just fine. In the code below, I have included a digitlWrite and analogWrite. The digitalWrite works, but the analogWrite doesn't write anything - i.e., always zero. The delay functions are working as ar the Serial.println statements. What am I missing?
#include <IRremote.h>
//int RECV_PIN = 13;
IRrecv irrecv(RECV_PIN);
decode_results results;
  // initialize the digital pin as an input.
  pinMode(13, INPUT);
  // Initialize pin 3 as OUTPUT for LED)
  pinMode (3, OUTPUT);
  irrecv.enableIRIn(); // Start the receiver
  int i=0;
   if (irrecv.decode(&results)) {
   translateIR();
 //  unknownRemoter();
     irrecv.resume(); // Receive the next value
 void translateIR() // takes action based on IR code received describing Car MP3 IR codes
   if (results.value == 0xC){
     Serial.println ("results was 0xC");
     digitalWrite (3, HIGH);
     delay (2000);
     digitalWrite (3,0);
     delay (2000);
     Serial.println ("start analogWrite");
     analogWrite(3, 25);
     delay (200);
     analogWrite(3, 50);
     delay (200);
     analogWrite (3, 75);
     delay (200);
     analogWrite (3, 50);
     delay (200);
     analogWrite (3, 25);
     delay (200);
     analogWrite (3, 0);
     delay (1000);
     Serial.println ("END");
What board are you using? There were some old boards where pin 3 wasn't a PWM pin.
What is connected to pin 3, i.e. what are you using to test that the analogWrite() is doing anything? Since you're only rapidly flipping up and down to a max of 75 (out of 255) it will need to be something pretty responsive.
Try doing analogWrite(3, 255) which is equivalent to a digitalWrite(3, HIGH) and see if that works.
Steve
Thanks for the response.
I'm using an Elegoo UNO R3. I wasn't aware that pin 3 didn't support pwm on some models. Checking, pin 3 is marked as pwm capable, and it does accept an analogWrite in test code. It only fails when I put it inside the ir routine.
My test circuit is a single LED which in other tests, is actually at about full brilliance at analog 80 or so. However, I tried it at 255 and still see nothing. The digitalWrite works just fine, even inside the ir routine.
I will try other pins just to see what happens.
My final version will be using a Pro-mini which also indicates pin 3 is analog capable. As a last resort, I can use a Pro-mini for the ir loop and do a digitalWrite to a second Pro-mini to actually do the analog function. A little clumsy, but possible. I'm a little cramped for space though so I'm still hoping there a one-Arduino solution.
Follow-up:
Some of this 'logic' just doesn't make sense sometimes! :slight_smile:
I tried the other analog pins - 5,6,9,10 and 11.
Of those, pins 6, 9, and 10 respond as expected to an analogWrite within the ir routine. pins 5 and 11 do not..
Don't understand the 'why' of it, but I can adjust the rest of my circuits to work with this.
Is this a timer issue?
Timer 2(?)
Don't know. Guess it could be. It's strange though that it seems to be related to the ir routine. Pin 3 works with a direct analogWrite outside the ir loop. I suspected maybe the fundamental pwm frequency might be interfering with the ir frequency somehow, but pin 3 and 10 use the same frequency. But while I'm into this, I will do some tests on another Arduino unit just so we can eliminate anything weird with this particular board.
Meanwhile I'm good with using pin 10 which is a functional solution, but doesn't provide a 'why'.
