analogWrite help
I have a basic Serial interface working, where a user can input values and they are saved to eeprom.
This is working as expected.
The value they enter will then be used to generate a PWM value on an analog pin with AnalogWrite.
If I want a value less than 100, the way I have coded the serial interface requires a 0 to be added before the value. IE 050.
The question which I cannot find an answer to googleing is:
can I use analogWrite(A1,050) ? for example, will it have the same effect as analogWrite(A1,50)?
or do I need to clip the leading 0 off before using it in analogWrite?
thanks in advance
You can use it but it won't do what you expect because a leading zero is an indication that the value is in Octal. Try Serial.println(050); to see what I mean
However, without seeing your full sketch it is impossible to say whether the user entering 050 will cause a problem or not because we don't know what data types you are using and how they are stored to EEPROM
Try it see if it works.
can you post that code? seems unnecessary
I will do, but i thought it may throw a spanner in the works and thought id ask before I get that far in the code and therefore be able to tackle it before spending hours scratching my head over it not working right.
here's one approach
void
loop (void)
    if (Serial.available ()) {
        char buf [90];
        int n = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
        buf [n] = '\0';
        char cmd [10];
        int  val;
        sscanf (buf, "%s%d", cmd, & val);
        Serial.print (" cmd ");
        Serial.print (cmd);
        Serial.print (", val ");
        Serial.println (val);
void
setup (void)
    Serial.begin (9600);
Probably, but until we see the code we don't know what @spruce_m00se is actually doing with it
File under I learned something today…
atoi() will work on "0x12bc", "12345" and "0177" and do what you'd expect. Or mess you right up. :expressionless:
Maybe things would have been easier if we only had eight fingers.
a7
