Hi, I can get my Android app to connect via Bluetooth to my Arduino, however no data can be transmitted between them, below is my setup and code:
HTC Anroid v2.2
Bluetooth mate gold modem
Arduino Mega (ATmega1280)
Android Java code:
package com.example.BluetoothExample;
import android.app.Activity;
import android.bluetooth.BluetoothAdapter;
import android.bluetooth.BluetoothDevice;
import android.bluetooth.BluetoothSocket;
import android.content.Intent;
import android.os.Bundle;
import android.os.Handler;
import android.view.View;
import android.widget.TextView;
import android.widget.EditText;
import android.widget.Button;
import android.widget.Toast;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.Set;
import java.util.UUID;
public class BluetoothExampleActivity extends Activity
TextView myLabel;
EditText myTextbox;
BluetoothAdapter mBluetoothAdapter;
BluetoothSocket mmSocket;
BluetoothDevice mmDevice;
OutputStream mmOutputStream;
InputStream mmInputStream;
Thread workerThread;
byte[] readBuffer;
int readBufferPosition;
int counter;
volatile boolean stopWorker;
@Override
public void onCreate(Bundle savedInstanceState)
super.onCreate(savedInstanceState);
setContentView(R.layout.main);
Button openButton = (Button)findViewById(R.id.open);
Button sendButton = (Button)findViewById(R.id.send);
Button closeButton = (Button)findViewById(R.id.close);
myLabel = (TextView)findViewById(R.id.label);
myTextbox = (EditText)findViewById(R.id.entry);
//Open Button
openButton.setOnClickListener(new View.OnClickListener()
public void onClick(View v)
try
findBT();
openBT();
catch (IOException ex) { }
//Send Button
sendButton.setOnClickListener(new View.OnClickListener()
try
sendData();
showMessage("SEND FAILED");
//Close button
closeButton.setOnClickListener(new View.OnClickListener()
try
closeBT();
void findBT()
mBluetoothAdapter = BluetoothAdapter.getDefaultAdapter();
if(mBluetoothAdapter == null)
myLabel.setText("No bluetooth adapter available");
if(!mBluetoothAdapter.isEnabled())
Intent enableBluetooth = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
startActivityForResult(enableBluetooth, 0);
Set<BluetoothDevice> pairedDevices = mBluetoothAdapter.getBondedDevices();
if(pairedDevices.size() > 0)
for(BluetoothDevice device : pairedDevices)
if(device.getName().equals("FireFly-108B"))
mmDevice = device;
myLabel.setText("Bluetooth Device Found");
void openBT() throws IOException
UUID uuid = UUID.fromString("00001101-0000-1000-8000-00805f9b34fb"); //Standard SerialPortService ID
mmSocket = mmDevice.createRfcommSocketToServiceRecord(uuid);
mmSocket.connect();
mmOutputStream = mmSocket.getOutputStream();
mmInputStream = mmSocket.getInputStream();
beginListenForData();
myLabel.setText("Bluetooth Opened");
void beginListenForData()
final Handler handler = new Handler();
final byte delimiter = 10; //This is the ASCII code for a newline character
stopWorker = false;
readBufferPosition = 0;
readBuffer = new byte[1024];
workerThread = new Thread(new Runnable()
public void run()
while(!Thread.currentThread().isInterrupted() && !stopWorker)
try
int bytesAvailable = mmInputStream.available();
if(bytesAvailable > 0)
byte[] packetBytes = new byte[bytesAvailable];
mmInputStream.read(packetBytes);
for(int i=0;i<bytesAvailable;i++)
byte b = packetBytes[i];
if(b == delimiter)
byte[] encodedBytes = new byte[readBufferPosition];
System.arraycopy(readBuffer, 0, encodedBytes, 0, encodedBytes.length);
final String data = new String(encodedBytes, "US-ASCII");
handler.post(new Runnable()
public void run()
myLabel.setText(data);
readBuffer[readBufferPosition++] = b;
stopWorker = true;
workerThread.start();
void sendData() throws IOException
String msg = myTextbox.getText().toString();
msg += "\n";
//mmOutputStream.write(msg.getBytes());
mmOutputStream.write('A');
myLabel.setText("Data Sent");
void closeBT() throws IOException
stopWorker = true;
mmOutputStream.close();
mmInputStream.close();
mmSocket.close();
myLabel.setText("Bluetooth Closed");
private void showMessage(String theMsg) {
Toast msg = Toast.makeText(getBaseContext(),
theMsg, (Toast.LENGTH_LONG)/160);
msg.show();
Arduino Code:
#include <SoftwareSerial.h>
int bluetoothTx = 45;
int bluetoothRx = 47;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
//pinMode(45, OUTPUT);
//pinMode(47, INPUT);
pinMode(53, OUTPUT);
//Setup usb serial connection to computer
//Setup Bluetooth serial connection to android
bluetooth.begin(115200);
bluetooth.print("$$");
delay(100);
bluetooth.println("U,9600,N");
bluetooth.begin(9600);
//Read from bluetooth and write to usb serial
if(bluetooth.available())
char toSend = (char)bluetooth.read();
Serial.print(toSend);
flashLED();
//Read from usb serial to bluetooth
if(Serial.available())
char toSend = (char)Serial.read();
bluetooth.print(toSend);
flashLED();
void flashLED()
digitalWrite(53, HIGH);
digitalWrite(53, LOW);
I've tried using 115200 and 9600 for the baud rates,
and I've tried setting the bluetooth rx and tx pins as input/output and output/input.
The Arduino is receiving serial data from the PC but can't send it to the Android (I can see this because of the flashLED() method). The Android can't send any data at all to the Arduino.
However they are both connected because the green light on the modem turns on and goes off and the red led flashes when I close the connection.
The sendData() method doesn't throw an exception because otherwise showMessage("SEND FAILED"); would appear.
Any help would be greatly appreciated!
Code take from: Android and Arduino Bluetooth communication | Matt Bell's Blog
