Android + Arduino Bluetooth Data Transfer
I can get my Android app to connect via Bluetooth to my Arduino. However no data can be transmitted between them. Below is my setup and code:
HTC Android v2.2, Bluetooth mate gold modem, Arduino Mega (ATmega1280)
Android Java code:
package com.example.BluetoothExample;
import android.app.Activity;
import android.bluetooth.BluetoothAdapter;
import android.bluetooth.BluetoothDevice;
import android.bluetooth.BluetoothSocket;
import android.content.Intent;
import android.os.Bundle;
import android.os.Handler;
import android.view.View;
import android.widget.TextView;
import android.widget.EditText;
import android.widget.Button;
import android.widget.Toast;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.Set;
import java.util.UUID;
public class BluetoothExampleActivity extends Activity {
  TextView myLabel;
  EditText myTextbox;
  BluetoothAdapter mBluetoothAdapter;
  BluetoothSocket mmSocket;
  BluetoothDevice mmDevice;
  OutputStream mmOutputStream;
  InputStream mmInputStream;
  Thread workerThread;
  byte[] readBuffer;
  int readBufferPosition;
  int counter;
  volatile boolean stopWorker;
  @Override
  public void onCreate(Bundle savedInstanceState) {
    super.onCreate(savedInstanceState);
    setContentView(R.layout.main);
    Button openButton = (Button)findViewById(R.id.open);
    Button sendButton = (Button)findViewById(R.id.send);
    Button closeButton = (Button)findViewById(R.id.close);
    myLabel = (TextView)findViewById(R.id.label);
    myTextbox = (EditText)findViewById(R.id.entry);
    //Open Button
    openButton.setOnClickListener(new View.OnClickListener() {
      public void onClick(View v) {
        try {
          findBT();
          openBT();
        catch (IOException ex) { }
    //Send Button
    sendButton.setOnClickListener(new View.OnClickListener() {
        try {
          sendData();
            showMessage("SEND FAILED");
    //Close button
    closeButton.setOnClickListener(new View.OnClickListener() {
        try {
          closeBT();
  void findBT() {
    mBluetoothAdapter = BluetoothAdapter.getDefaultAdapter();
    if(mBluetoothAdapter == null) {
      myLabel.setText("No bluetooth adapter available");
    if(!mBluetoothAdapter.isEnabled()) {
      Intent enableBluetooth = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
      startActivityForResult(enableBluetooth, 0);
    Set<BluetoothDevice> pairedDevices = mBluetoothAdapter.getBondedDevices();
    if(pairedDevices.size() > 0) {
      for(BluetoothDevice device : pairedDevices) {
        if(device.getName().equals("FireFly-108B")) {
          mmDevice = device;
    myLabel.setText("Bluetooth Device Found");
  void openBT() throws IOException {
    UUID uuid = UUID.fromString("00001101-0000-1000-8000-00805f9b34fb"); //Standard //SerialPortService ID
    mmSocket = mmDevice.createRfcommSocketToServiceRecord(uuid);
    mmSocket.connect();
    mmOutputStream = mmSocket.getOutputStream();
    mmInputStream = mmSocket.getInputStream();
    beginListenForData();
    myLabel.setText("Bluetooth Opened");
  void beginListenForData() {
    final Handler handler = new Handler();
    final byte delimiter = 10; //This is the ASCII code for a newline character
    stopWorker = false;
    readBufferPosition = 0;
    readBuffer = new byte[1024];
    workerThread = new Thread(new Runnable() {
      public void run() {
         while(!Thread.currentThread().isInterrupted() && !stopWorker) {
          try {
            int bytesAvailable = mmInputStream.available();
            if(bytesAvailable > 0) {
              byte[] packetBytes = new byte[bytesAvailable];
              mmInputStream.read(packetBytes);
              for(int i=0;i<bytesAvailable;i++) {
                byte b = packetBytes[i];
                if(b == delimiter) {
                  byte[] encodedBytes = new byte[readBufferPosition];
                  System.arraycopy(readBuffer, 0, encodedBytes, 0, encodedBytes.length);
                  final String data = new String(encodedBytes, "US-ASCII");
                  handler.post(new Runnable() {
                    public void run() {
                      myLabel.setText(data);
                else {
                  readBuffer[readBufferPosition++] = b;
            stopWorker = true;
    workerThread.start();
  void sendData() throws IOException {
    String msg = myTextbox.getText().toString();
    msg += "\n";
    //mmOutputStream.write(msg.getBytes());
    mmOutputStream.write('A');
    myLabel.setText("Data Sent");
  void closeBT() throws IOException {
    stopWorker = true;
    mmOutputStream.close();
    mmInputStream.close();
    mmSocket.close();
    myLabel.setText("Bluetooth Closed");
  private void showMessage(String theMsg) {
        Toast msg = Toast.makeText(getBaseContext(),
                theMsg, (Toast.LENGTH_LONG)/160);
        msg.show();
Arduino Code:
#include <SoftwareSerial.h>
int bluetoothTx = 45;
int bluetoothRx = 47;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
  //pinMode(45, OUTPUT);
  //pinMode(47, INPUT);
  pinMode(53, OUTPUT);
  //Setup usb serial connection to computer
  //Setup Bluetooth serial connection to android
  bluetooth.begin(115200);
  bluetooth.print("$$$");
  delay(100);
  bluetooth.println("U,9600,N");
  bluetooth.begin(9600);
  //Read from bluetooth and write to usb serial
  if(bluetooth.available()) {
  char toSend = (char)bluetooth.read();
  Serial.print(toSend);
  flashLED();
  //Read from usb serial to bluetooth
  if(Serial.available()) {
  char toSend = (char)Serial.read();
  bluetooth.print(toSend);
  flashLED();
void flashLED() {
  digitalWrite(53, HIGH);
  digitalWrite(53, LOW);
I've tried using 115200 and 9600 for the baud rates, and I've tried setting the bluetooth rx and tx pins as input/output and output/input. The Arduino is receiving serial data from the PC but can't send it to the Android (I can see this because of the flashLED() method).
The Android can't send any data at all to the Arduino. However they are both connected because the green light on the modem turns on and goes off and the red led flashes when I close the connection. The sendData() method doesn't throw an exception because otherwise showMessage("SEND FAILED"); would appear.
I also have this in my manifest .XML
<uses-permission android:name="android.permission.BLUETOOTH" />
<uses-sdk android:minSdkVersion="8" android:targetSdkVersion="8" />
Any help would be greatly appreciated!
Whatever you have got, the other will only work when you specifically configure it to do so. I believe the RN41 is 115200 by default, so don't expect that to work with software serial unless you reconfigure it to 9600 . Further, your Mega has four (4) hardware serial ports, any of which will be fine @ 115200, so I don't suppose you have good reason for using software serial anyway. Just ditch the library and use serial1 on pins 18,19. Similarly, the only wiring connection that will work is the correct one - Rx to Tx and Tx to Rx.
Then test it with a standard Bluetooth terminal app, like that by Morisch.
