Hab ich eingestellt und hier die Ausgabe:
(vermute das noch die in.h fehlt, aber die kann ich im Internet nicht finden)
Arduino: 1.8.19 (Mac OS X), Board: "LOLIN(WEMOS) D1 mini (clone), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, DOUT (compatible), 40MHz, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/shnu/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/shnu/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/shnu/Documents/Arduino/libraries -fqbn=esp8266:esp8266:d1_mini_clone:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,FlashMode=dout,FlashFreq=40,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10819 -build-path /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043 -warnings=all -build-cache /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_cache_570011 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs-3.1.0-gcc10.3-e5f9fec.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs-3.1.0-gcc10.3-e5f9fec.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.python3.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.1.0-gcc10.3-e5f9fec.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec -verbose /Volumes/Intenso SSD intern/Arduino/RSTP_ESP8266/RSTP_ESP8266.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/shnu/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/shnu/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/shnu/Documents/Arduino/libraries -fqbn=esp8266:esp8266:d1_mini_clone:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,FlashMode=dout,FlashFreq=40,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10819 -build-path /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043 -warnings=all -build-cache /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_cache_570011 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs-3.1.0-gcc10.3-e5f9fec.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs-3.1.0-gcc10.3-e5f9fec.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.python3.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.1.0-gcc10.3-e5f9fec.path=/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec -verbose /Volumes/Intenso SSD intern/Arduino/RSTP_ESP8266/RSTP_ESP8266.ino
Using board 'd1_mini_clone' from platform in folder: /Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1
Using core 'esp8266' from platform in folder: /Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1
/Users/shnu/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 -I /Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/mkbuildoptglobals.py /Applications/Arduino.app/Contents/Java 10819 /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043 /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core/build.opt "/Volumes/Intenso SSD intern/Arduino/RSTP_ESP8266/RSTP_ESP8266.ino.globals.h" /Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/cores/esp8266/CommonHFile.h
Using preferences from '/Users/shnu/Library/Arduino15/preferences.txt'
preferences.txt: compiler.cache_core=true
Clean build, created dir /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core
Note: optional global include file '/Volumes/Intenso SSD intern/Arduino/RSTP_ESP8266/RSTP_ESP8266.ino.globals.h' does not exist.
Read more at https://arduino-esp8266.readthedocs.io/en/latest/faq/a06-global-build-options.html
Detecting libraries used...
/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core/build.opt -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/lwip2/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core -c @/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/warnings/none-g++ -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini_clone\"" -DFLASHMODE_DOUT -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/cores/esp8266 -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/variants/d1_mini /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/sketch/RSTP_ESP8266.ino.cpp -o /dev/null
Alternatives for AudioTools.h: [arduino-audio-tools-0.9.6@0.9.5]
ResolveLibrary(AudioTools.h)
-> candidates: [arduino-audio-tools-0.9.6@0.9.5]
/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core/build.opt -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/lwip2/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core -c @/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/warnings/none-g++ -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini_clone\"" -DFLASHMODE_DOUT -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/cores/esp8266 -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/variants/d1_mini -I/Users/shnu/Documents/Arduino/libraries/arduino-audio-tools-0.9.6/src /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/sketch/RSTP_ESP8266.ino.cpp -o /dev/null
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core/build.opt -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/lwip2/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core -c @/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/warnings/none-g++ -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini_clone\"" -DFLASHMODE_DOUT -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/cores/esp8266 -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/variants/d1_mini -I/Users/shnu/Documents/Arduino/libraries/arduino-audio-tools-0.9.6/src -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/ESP8266WiFi/src /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/sketch/RSTP_ESP8266.ino.cpp -o /dev/null
Alternatives for Ticker.h: [Ticker@1.0]
ResolveLibrary(Ticker.h)
-> candidates: [Ticker@1.0]
/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core/build.opt -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/lwip2/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core -c @/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/warnings/none-g++ -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini_clone\"" -DFLASHMODE_DOUT -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/cores/esp8266 -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/variants/d1_mini -I/Users/shnu/Documents/Arduino/libraries/arduino-audio-tools-0.9.6/src -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/ESP8266WiFi/src -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/Ticker/src /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/sketch/RSTP_ESP8266.ino.cpp -o /dev/null
Alternatives for I2S.h: [I2S@1.0]
ResolveLibrary(I2S.h)
-> candidates: [I2S@1.0]
/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core/build.opt -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/lwip2/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core -c @/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/warnings/none-g++ -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini_clone\"" -DFLASHMODE_DOUT -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/cores/esp8266 -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/variants/d1_mini -I/Users/shnu/Documents/Arduino/libraries/arduino-audio-tools-0.9.6/src -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/ESP8266WiFi/src -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/Ticker/src -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/I2S/src /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/sketch/RSTP_ESP8266.ino.cpp -o /dev/null
Alternatives for AudioStreamer.h: [Micro-RTSP-Audio-0.3@0.1.0]
ResolveLibrary(AudioStreamer.h)
-> candidates: [Micro-RTSP-Audio-0.3@0.1.0]
/Users/shnu/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core/build.opt -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/lwip2/include -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/core -c @/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/tools/warnings/none-g++ -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini_clone\"" -DFLASHMODE_DOUT -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/cores/esp8266 -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/variants/d1_mini -I/Users/shnu/Documents/Arduino/libraries/arduino-audio-tools-0.9.6/src -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/ESP8266WiFi/src -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/Ticker/src -I/Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/I2S/src -I/Users/shnu/Documents/Arduino/libraries/Micro-RTSP-Audio-0.3/src /var/folders/28/0plspyr11gd358d3sg28hyvm0000gn/T/arduino_build_711043/sketch/RSTP_ESP8266.ino.cpp -o /dev/null
Alternatives for netinet/in.h: []
ResolveLibrary(netinet/in.h)
-> candidates: []
In file included from /Users/shnu/Documents/Arduino/libraries/Micro-RTSP-Audio-0.3/src/../include/platglue.h:6,
from /Users/shnu/Documents/Arduino/libraries/Micro-RTSP-Audio-0.3/src/platglue.h:2,
from /Users/shnu/Documents/Arduino/libraries/Micro-RTSP-Audio-0.3/src/AudioStreamer.h:14,
from /Users/shnu/Documents/Arduino/libraries/arduino-audio-tools-0.9.6/src/AudioLibs/RTSPStream.h:3,
from /Volumes/Intenso SSD intern/Arduino/RSTP_ESP8266/RSTP_ESP8266.ino:2:
/Users/shnu/Documents/Arduino/libraries/Micro-RTSP-Audio-0.3/src/../include/platglue-posix.h:4:10: fatal error: netinet/in.h: No such file or directory
4 | #include <netinet/in.h>
compilation terminated.
Bibliothek arduino-audio-tools-0.9.6 in Version 0.9.5 im Ordner: /Users/shnu/Documents/Arduino/libraries/arduino-audio-tools-0.9.6 wird verwendet
Bibliothek ESP8266WiFi in Version 1.0 im Ordner: /Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/ESP8266WiFi wird verwendet
Bibliothek Ticker in Version 1.0 im Ordner: /Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/Ticker wird verwendet
Bibliothek I2S in Version 1.0 im Ordner: /Users/shnu/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.1/libraries/I2S wird verwendet
Bibliothek Micro-RTSP-Audio-0.3 in Version 0.1.0 im Ordner: /Users/shnu/Documents/Arduino/libraries/Micro-RTSP-Audio-0.3 wird verwendet
exit status 1
Fehler beim Kompilieren für das Board LOLIN(WEMOS) D1 mini (clone).
