Angular processing software syntax error float angle
#include <Servo.h>
#include <Wire.h>
Servo myservo;
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
int pos = 0;
const int trigPin = 9;
const int echoPin = 10;
const int moteur = 11;
const int buzzer = 12;
const int ledPin1 = 14;
const int ledPin2 = 15;
float distanceCm, DistanceSec, duration;
Serial.begin(9600); // Initialize serial communication
myservo.attach(moteur);
lcd.init(); // Initialize the LCD
lcd.backlight(); // Turn on the backlight
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(buzzer, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
DistanceSec = 20;
for (pos = 0; pos <= 180; pos += 1) {
#Processing software code
import processing.serial.*;
Serial myPort;
float angle, distance;
int maxDistance = 100;
size(800, 600);
String portName = Serial.list()[0]; // Change this to the correct port number
myPort = new Serial(this, portName, 9600);
void draw() {
background(0);
translate(width / 2, height);
// Draw radar arc
noFill();
stroke(0, 255, 0);
arc(0, 0, width, width, PI, TWO_PI);
// Draw distance circles
for (int i = 1; i <= 4; i++) {
float radius = (width / 2) * (i / 5.0);
ellipse(0, 0, radius * 2, radius * 2);
textAlign(RIGHT, CENTER);
text(i * 25 + "cm", -5, -radius);
// Draw angle lines
for (int i = 0; i <= 180; i += 30) {
float x = (width / 2) * cos(radians(i));
float y = (width / 2) * sin(radians(i));
line(0, 0, x, -y);
textAlign(CENTER, CENTER);
text(i + "°", x, -y - 10);
// Draw radar line
stroke(255, 0, 0);
line(0, 0, (width / 2) * cos(radians(angle)), -(width / 2) * sin(radians(angle)));
// Draw object
if (distance > 0 && distance <= maxDistance) {
float objectX = ((width / 2) * (distance / maxDistance)) * cos(radians(angle));
float objectY = -((width / 2) * (distance / maxDistance)) * sin(radians(angle));
fill(255, 0, 0);
ellipse(objectX, objectY, 10, 10);
// Display angle and distance
textAlign(LEFT, TOP);
fill(255);
text("Angle: " + int(angle) + "°", 10, 10);
text("Distance: " + int(distance) + " cm", 10, 30);
void serialEvent(Serial myPort) {
String data = myPort.readStringUntil('\n');
if (data != null) {
data = trim(data);
String[] values = split(data, ',');
if (values.length == 2) {
angle = float(values[0]);
distance = float(values[1]);
Serial myPort;
float angle = 0;
float distance = 0;
size(800, 600);
println("Available serial ports:");
printArray(Serial.list());
// Pilih port serial yang sesuai
String portName = Serial.list()[0]; // Ubah indeks jika perlu
void draw() {
background(0);
// Basic visualization
translate(width/2, height);
stroke(0, 255, 0);
line(0, 0,
(width/2) * cos(radians(angle)),
-(height/2) * sin(radians(angle)));
// Display current values
fill(255);
text("Angle: " + angle, 10, 10);
text("Distance: " + distance, 10, 30);
try {
if (data != null) {
data = trim(data);
} catch (Exception e) {
println("Error reading serial: " + e.getMessage());
