Do you want to a graph some data on a Cartesian coordinate system using your LCD but don't want to write the code? Use mine for free. This code (listed below) includes a function do plot your data on a graph. This function works with Arduino UNO or MEGA, and an Adafruit 3.5 inch 320 x 480 LDC display. This code may work with other displays that use the Adafruit_GFX libraries.
Arduino INO file (on pcloud)
http://pc.cd/s0crtalK
or
https://my.pcloud.com/publink/show?code=XZbjlRZFugqO0frDk5ROiQXOJT35F5CbQP7
Link to the Adafruit LCD display and libraries
Enjoy.
This program provides cartesian type graph function
It requires and Arduino Mega (or UNO) and an Adafruit 3.5" TFT 320x480 + Touchscreen Breakout Board
https://learn.adafruit.com/adafruit-3-5-color-320x480-tft-touchscreen-breakout/overview
Note: other LCD's could be used but will require some modifications to this code
Adafruit libraries
https://github.com/adafruit/Adafruit_HX8357_Library/archive/master.zip
https://github.com/adafruit/Adafruit-GFX-Library/archive/master.zip
optional touch screen libraries
https://github.com/adafruit/Touch-Screen-Library/archive/master.zip
Revisions
rev date author description
1 12-24-2015 kasprzak initial creation
This pin setting will also operate the SD card
Pin settings
Arduino device
5V Vin
GND GND
A0
A1
A2 Y+ (for touch screen use)
A3 X- (for touch screen use)
A4
A5
1
2
3
4 CCS (42 for mega)
5
6
7 Y- (44 for mega)
8 X+ (46 for mega)
9 DC (48 on mega * change define)
10 CS (53 for mega * change define)
11 MOSI (51 for mega)
12 MISO (50 for mega)
13 CLK (SCK) (52 for mega)
44 Y- (for touch screen only)
46 X+ (for touch screen only)
48 DC
SDA
SLC
#include "Adafruit_HX8357.h"
#define TFT_CS 53
#define TFT_DC 48
#define TFT_RST 8 // RST can be set to -1 if you tie it to Arduino's reset
#define SD_CCS 42
#define LTBLUE 0xB6DF
#define LTTEAL 0xBF5F
#define LTGREEN 0xBFF7
#define LTCYAN 0xC7FF
#define LTRED 0xFD34
#define LTMAGENTA 0xFD5F
#define LTYELLOW 0xFFF8
#define LTORANGE 0xFE73
#define LTPINK 0xFDDF
#define LTPURPLE 0xCCFF
#define LTGREY 0xE71C
#define BLUE 0x001F
#define TEAL 0x0438
#define GREEN 0x07E0
#define CYAN 0x07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define ORANGE 0xFC00
#define PINK 0xF81F
#define PURPLE 0x8010
#define GREY 0xC618
#define WHITE 0xFFFF
#define BLACK 0x0000
#define DKBLUE 0x000D
#define DKTEAL 0x020C
#define DKGREEN 0x03E0
#define DKCYAN 0x03EF
#define DKRED 0x6000
#define DKMAGENTA 0x8008
#define DKYELLOW 0x8400
#define DKORANGE 0x8200
#define DKPINK 0x9009
#define DKPURPLE 0x4010
#define DKGREY 0x4A49
Adafruit_HX8357 display = Adafruit_HX8357(TFT_CS, TFT_DC);
// these are the only external variables used by the graph function
// it's a flag to draw the coordinate system only on the first call to the Graph() function
// and will mimize flicker
// also create some variables to store the old x and y, if you draw 2 graphs on the same display
// you will need to store ox and oy per each display
boolean display1 = true;
double ox , oy ;
double x, y;
display.begin(HX8357D);
display.fillScreen(BLACK);
display.setRotation(3);
for (x = 0; x <= 6.3; x += .1) {
y = sin(x);
Graph(display, x, y, 60, 290, 390, 260, 0, 6.5, 1, -1, 1, .25, "Sin Function", "x", "sin(x)", DKBLUE, RED, YELLOW, WHITE, BLACK, display1);
void loop(void) {
function to draw a cartesian coordinate system and plot whatever data you want
just pass x and y and the graph will be drawn
huge arguement list
&d name of your display object
x = x data point
y = y datapont
gx = x graph location (lower left)
gy = y graph location (lower left)
w = width of graph
h = height of graph
xlo = lower bound of x axis
xhi = upper bound of x asis
xinc = division of x axis (distance not count)
ylo = lower bound of y axis
yhi = upper bound of y asis
yinc = division of y axis (distance not count)
title = title of graph
xlabel = x asis label
ylabel = y asis label
gcolor = graph line colors
acolor = axi ine colors
pcolor = color of your plotted data
tcolor = text color
bcolor = background color
&redraw = flag to redraw graph on fist call only
void Graph(Adafruit_HX8357 &d, double x, double y, double gx, double gy, double w, double h, double xlo, double xhi, double xinc, double ylo, double yhi, double yinc, String title, String xlabel, String ylabel, unsigned int gcolor, unsigned int acolor, unsigned int pcolor, unsigned int tcolor, unsigned int bcolor, boolean &redraw) {
double ydiv, xdiv;
double i;
double temp;
int rot, newrot;
if (redraw == true) {
redraw = false;
// initialize old x and old y in order to draw the first point of the graph
// but save the transformed value
// note my transform funcition is the same as the map function, except the map uses long and we need doubles
ox = (x - xlo) * ( w) / (xhi - xlo) + gx;
oy = (y - ylo) * (gy - h - gy) / (yhi - ylo) + gy;
// draw y scale
for ( i = ylo; i <= yhi; i += yinc) {
// compute the transform
temp = (i - ylo) * (gy - h - gy) / (yhi - ylo) + gy;
if (i == 0) {
d.drawLine(gx, temp, gx + w, temp, acolor);
else {
d.drawLine(gx, temp, gx + w, temp, gcolor);
// draw the axis labels
d.setTextSize(1);
d.setTextColor(tcolor, bcolor);
d.setCursor(gx - 40, temp);
// precision is default Arduino--this could really use some format control
d.println(i);
// draw x scale
for (i = xlo; i <= xhi; i += xinc) {
temp = (i - xlo) * ( w) / (xhi - xlo) + gx;
if (i == 0) {
d.drawLine(temp, gy, temp, gy - h, acolor);
else {
d.drawLine(temp, gy, temp, gy - h, gcolor);
d.setTextSize(1);
d.setCursor(temp, gy + 10);
d.println(i);
//now draw the graph labels
d.setTextSize(2);
d.setCursor(gx , gy - h - 30);
d.println(title);
d.setTextSize(1);
d.setTextColor(acolor, bcolor);
d.setCursor(gx , gy + 20);
d.println(xlabel);
d.setTextSize(1);
d.setCursor(gx - 30, gy - h - 10);
d.println(ylabel);
// the coordinates are now drawn, plot the data
// the entire plotting code are these few lines...
// recall that ox and oy are initialized above
d.drawLine(ox, oy, x, y, pcolor);
// it's up to you but drawing 2 more lines to give the graph some thickness
d.drawLine(ox, oy + 1, x, y + 1, pcolor);
d.drawLine(ox, oy - 1, x, y - 1, pcolor);
ox = x;
oy = y;
End of graphing function
