Another noob question about resistors
Hi, I am learning eletronics and Arduino right now, and I have one question about resistors.
In some examples the resistor is placed between Pin wire and the Led
In another examples the resistor is placed between Led and ground wire
So, wich on is the correct?
klamarth:
They both are. In a series circuit such as that, it does not matter the order of how the led and resistor are wired. What is important is that the diode direction is wired correctly as it will not function if wired backwards, and that the resistor have the proper ohm and wattage values for the circuit it's being used in.
Lefty
Electrically, they are both correct. However, I would consider it good practice to install the resistor to the output pin and the LED to the ground pin. The reason being that, if you screw up part of your hook-up there is a good chance the resistor will still , provide current limitation protection to your arduino.
