hi there . I'm real new to the Arduino , though I've been trying to read & learn . I have a project that I would like to try & need some input on which Arduino I would need for the project .Like the title says I would like to be able to control a treadmill motor with a MC2100 treadmill controller board using a Arduino . What I would like to have is a 4 x 4 keypad that I can punch in my desired speed to , & have a tach with feedback to keep the motor at set speed & read the set & actual speed on a display , & if possible have a relay in there that can reverse the motor direction by using one of the non number keys on the keyboard .
I have seen some conversations about a project like this but not with all the functions I would like to have .
The MC2100 has PWN input so I know that I can get PWM out of a Arduino . I have a few UNO's, will they be powerful enough for this project or should i get a different Arduino ?
thank you
Animal
I'll answer your last question first.
Yes.
On the other hand, unless you provide the datasheet or schematic for the "MC2100 treadmill controller board", no one is going to be able to help you.
my treadmill uses a simple pot to change speed.
I use a hand controlled pot and I did look at using a motor controlled pot.
decided there was no benefit on my lathe for speed control.
for PWM, you need to use a optoisolator so you do not share any wires between the two boards.
lots of people have done what you ask, but with discrete parts. RPM display, speed control, etc.
if you google, there are some 555 circuits that PWM for that motor driver. You can replace that 555 circuit with one PWM out from the Arudino.
Motor RPM is best with an actual tacho, reflective paint, IR sensor, also well documented for Arduinos.
I would highly suggest you search this forum for treadmill as this does come up a couple times a year.
I have that controller board and most of the info I found on it came from this blog:MC-2100 Motor Controller | Sons of Invention
It's been a long time since I messed with it but I did write a program that gives the correct 20 hz PWM that it requires that I would be glad to share.
/* ================= HEADER ==================
PROJECT: Treadmill speed Control
Using a MC-2100 controller that requires a 20 hz phase correct PWM signal with a 0-85% dutycycle
VERSION: 0.0.1
IDE VERSION: 1.8.9
HARDWARE: Nano (328p)
Potentiometer
MC-2100 REV.B Motor Controller
Treadmill Motor
// ================= CONSTANTS ================
constexpr uint8_t PWM_PIN = 10;
constexpr uint16_t SPEED_POT = A0;
// ================= VARIABLES ================
uint16_t dutyCycle;
// * SETUP *
pinMode(PWM_PIN, OUTPUT);
init20hzPWM();
}// End setup()
// * MAIN PROGRAM LOOP *
getDutyCycle();
applyDutyCycle();
}// End loop()
// * getDutyCycle() *
void getDutyCycle()
constexpr uint16_t MIN_DUTY = 0;
constexpr uint16_t MAX_DUTY = 5300; // 85% of TOP_COUNT
uint16_t rawPot = analogRead(SPEED_POT);
dutyCycle = map2(rawPot, 0, 1023, MIN_DUTY, MAX_DUTY);
}// End getDutyCycle()
// * applyDutyCycle() *
void applyDutyCycle()
static uint16_t oldDutyCycle;
if (oldDutyCycle != dutyCycle)
OCR1A = dutyCycle; // setting OCR1x applies dutyCycle
oldDutyCycle = dutyCycle;
}// End applyDutyCycle()
// * init20hzPWM() *
// * Set up Timer1 for 20hz phase correct PWM output on pin 9 *
void init20hzPWM()
constexpr uint16_t PRESCALER = 64; // clock divisor
constexpr uint16_t FREQUENCY = 20; // Herz
constexpr uint16_t TOP_COUNT = F_CPU / PRESCALER / FREQUENCY / 2; // Formula derived from Secrets of Arduino PWM (http://www.righto.com/2009/07/secrets-of-arduino-pwm.html)
// Set prescaler to /64
TCCR1B |= (1 << CS10) | (1 << CS11);
//TCCR1A |= (1 << WGM10) | (1 << WGM11); // Set WGM mode 11 - phase correct pwm using OCR1A as TOP
TCCR1A |= (1 << WGM11); // Set WGM mode 10 - phase correct pwm using ICR1 as TOP
TCCR1B |= (1 << WGM13);
//OCR1A = TOP_COUNT;
ICR1 = TOP_COUNT;
//TCCR1A |= (1 << COM1A1) | (1 << COM1B1); // Set Timer1 to output on pins 9(OC1A) and 10(OC1B), WGM mode 11
TCCR1A |= (1 << COM1A1); // Set Timer1 to output on pin 9(OC1A), WGM mode 10
//OCR1B = dutyCycle; // output on pin 10, pin 9 tied up, WGM mode 11
OCR1A = dutyCycle; // output on pin 9, WGM mode 10
}// End init20hzPWM()
// * map2() *
// * bperrybap https://forum.arduino.cc/index.php?topic=417690.30 *
int32_t map2(int32_t x, int32_t in_min, int32_t in_max, int32_t out_min, int32_t out_max)
if( x == in_max)
return out_max;
else if(out_min < out_max)
return (x - in_min) * (out_max - out_min+1) / (in_max - in_min) + out_min;
return (x - in_min) * (out_max - out_min-1) / (in_max - in_min) + out_min;
} // End map2()
EDIT: I should of cleaned that prog up a little but it will have to wait gotta go to work.
Here's info on the motor controller & board pinouts . yea , you can run a MC 40 or MC 80 with just a pot , but the MC 2100 needs some sort of PWM input & I would like to see if I could do one with a few more bells & whistle's
thanks
animal
ok the PDF didn't get through , lets try again
animal
animal12:
thanks
animal
Specifically The MC-2100 requires a 20hz PWM which is not the default frequency of the Arduino.
That's why I wrote this program that sets up timer 1 to output the correct frequency. Currently it uses a pot for input control but you can modify the getDutyCycle() function to accept any kind of input you like everything else can remain unchanged.
Here is a cleaned up version of the code I posted earlier as promised:
PROJECT: Treadmill motor speed Control
Output is on Pin 9
VERSION: 0.0.2
IDE VERSION: 1.8.9
HARDWARE: Uno/Nano (328p)
Potentiometer
Treadmill Motor
constexpr uint8_t SPEED_POT = A0;
// * SETUP *
// Initializes timer 1 to produce a 20 hz pwm
init20hzPWM();
}// End setup()
applyDutyCycle(getDutyCycle());
}// End loop()
uint16_t getDutyCycle()
uint16_t dutyCycle = map(rawPot, 0, 1023, MIN_DUTY, MAX_DUTY);
return dutyCycle;
void applyDutyCycle(uint16_t dutyCycle)
void init20hzPWM()
// clock divisor
// Desired Frequncy in Herz
// (http://www.righto.com/2009/07/secrets-of-arduino-pwm.html)
ICR1 = TOP_COUNT;
// initialize to 0(off)
OCR1A = 0; // output on pin 9, WGM mode 10
Thanks Hutkikz , I'll try to mess with it this weekend
animal
