I recently salvaged this 20x2 VFD from an HP DesignJet 7550M (a large format printer). I'd love to use it for other projects, but I can't any datasheets on it. I can't really find much at all.
Here it is:
I found great info on the Samsung 20T202DA2JA, which Adafruit used to sell. However, that VFD uses an NEC D16314 controller chip, and the one I have doesn't. Should this data still work? I'm no serial communication expert, but I figured the registers would be way off and the code wouldn't carry over.
I found a datasheet for the Toshiba TD62C950RF chips on the board - they are shift registers. Is that the info I need to get these things working?
I couldn't find any info on the other major chip on the board, the Samsung 9704-20T201. I figured that's the datasheet I need.
Can anyone provide direction on how to go about getting this thing to work? Any guidance would be much appreciated.
In a forum I found the following pinout and marked the pins which I found out to be correct after inspecting the PCB:
1: Vcc -- confirmed
2: Clock
3: GND -- confirmed
4: Data
5: Reset
-- from circuitonline.net (3rd post)
After connecting only VCC to 5v and GND the display showed random characters, I think they are picked up by signal pins from the air (?). But when I try it again now, it doesn't show anything!
I measured how much current it drew: 500mA. I'll try the I2Cscanner tomorrow.
Thank you for that idea!
UPDATE:
No, no I2C interface. But while scanning, random characters showed up like before. So essentially it is working.
The other option is a SPI-like interface, but is there a way to figure out the commands?
Yes only to aware 120 days old this post I know, but then i think the information wasnt available Its is now thanks to the kind co operation of a company today Im also looking at these to see how to implement Im happy to say here is that datasheet for anyone with continued interest
