Any Idea when it will be available?
Could come in real handy, like trying to add other hardware!
Arduino UNO Breakout Carrier — Arduino Online Shop
I already clicked on the notify email...
Is this board intended for use with any Arduino Uno or just the Uno Q ?
@UKHeliBob
It's my understanding that that board os for the Q boards; it gives access to the bottom headers.
A good example of confusing naming.
It is designed to connect to the "high-speed headers" that are located on the bottom of the UNO Q board:
šŸ“·
ABX00162-full-pinout.pdf by Arduino - CC BY-SA 4.0 (cropped, border added)
So it can only be used with boards that have these headers. In addition to the UNO Q, the VENTUNO Q also has these headers, and so will be usable with the carrier.
That was my feeling too
This really is taking the Uno name too far
Literally looks like a must have for all of us Uno Q owners. I might need buy something else for justifying spending only 10$ and shipping
For the breakout carrier to be useful for the users, the pin functions should be well understood. The attached file is from Qualcomm, but it has not clearly described the purposes of the MPU signals. The Arduino Dev Team may take initiative in this regards,
Pin descriptions for the MPU can be found in the attached file:
PinDiagramQBR2210.pdf (1006.0 KB)
Hi, @ptillisch
Can you advise the marketing or design people of thier confusing naming and get it right please.
Arduino UNO Q Breakout Carrier
Its the little things that stuff up a good thing.
Tom.... :smiley: :+1: :coffee: :australia:
PS. if its not listed correctly then I assume Aliexpress runs the Arduino Store.
The problem with the name you propose is that it would imply the carrier is specific to the UNO Q. It is instead usable with any of the boards that have the standardized "high-speed headers". That will include the VENTUNO Q in addition to the UNO Q, and likely future boards as well.
I played Uno the card game as a child you know? Also the phrase 'you know' or 'ya know' is a common phrase people use to pause between sentences.
Try not to think about it and you'll start seeing Uno everywhere. It's the White Bear principle of psychology. :upside_down_face:
Well back on topic that Ventuno (Venture + Uno?) seems to be a very powerful piece of professional equipment
Well, call it the "Arduino High Speed Headers Break Out Board"
Tell it like it really is..
Marketing can use that free of my copyright...
Note: my excel document has some information on the JMISC pins of the STM32...
25 JMISC PC6 CSLEEP - TIM3_CH1 TIM8_CH1 - - MDF1_CKI3 - SDMMC1_
D0DIR
TSC_G4_IO1 DCMI_D0/PSSI_D0 SDMMC2_D6 SDMMC1_D6 SAI2_MCLK_A - EVENTOUT
26 JMISC PD2 TRACED2 - TIM3_ETR - - - - USART3_
RTS/USART3_
DE
UART5_RX TSC_SYNC DCMI_D11/
PSSI_D11
LPGPIO1_P7 SDMMC1_CMD LPTIM4_ETR - EVENTOUT
27 JMISC PC7 CDSTOP - TIM3_CH2 TIM8_CH2 - - MDF1_SDI3 - SDMMC1_
D123DIR
TSC_G4_IO2 DCMI_D1/PSSI_D1 SDMMC2_D7 SDMMC1_D7 SAI2_MCLK_B LPTIM2_CH2 EVENTOUT
28 JMISC PE2 TRACECLK - TIM3_ETR SAI1_CK1 - - - - - TSC_G7_IO1 - LPGPIO1_P14 FMC_A23 SAI1_MCLK_A - EVENTOUT
29 JMISC PC8 SRDSTOP - TIM3_CH3 TIM8_CH3 - - - - - TSC_G4_IO3 DCMI_D2/PSSI_D2 - SDMMC1_D0 - LPTIM3_CH1 EVENTOUT
30 JMISC PE3 TRACED0 - TIM3_CH1 OCTOSPIM_
P1_DQS
- - - - - TSC_G7_IO2 - LPGPIO1_P15 FMC_A19 SAI1_SD_B - EVENTOUT
31 JMISC PC9 TRACED0 TIM8_BKIN2 TIM3_CH4 TIM8_CH4 DCMI_D3/
PSSI_D3
- - - - TSC_G4_IO4 OTG_FS_NOE - SDMMC1_D1 - LPTIM3_CH2 EVENTOUT
32 JMISC PE5 TRACED2 - TIM3_CH3 SAI1_CK2 - - MDF1_CKI3 - - TSC_G7_IO4 DCMI_D6/PSSI_D6 - FMC_A21 SAI1_SCK_A - EVENTOUT
33 JMISC PE4 TRACED1 - TIM3_CH2 SAI1_D2 - - MDF1_SDI3 - - TSC_G7_IO3 DCMI_D4/PSSI_D4 - FMC_A20 SAI1_FS_A - EVENTOUT
34 JMISC PE6 TRACED3 - TIM3_CH4 SAI1_D1 - - - - - - DCMI_D7/PSSI_D7 - FMC_A22 SAI1_SD_A - EVENTOUT
35 JMISC PI4 - - - TIM8_BKIN - SPI2_RDY - - - - DCMI_D5/PSSI_D5 - - - - EVENTOUT
36 JMISC PE7 - TIM1_ETR - - - - MDF1_SDI2 - - - - - FMC_D4/FMC_
AD4
37 JMISC PI6 - - - TIM8_CH2 - OCTOSPIM_
P2_CLK
- - - - DCMI_D6/PSSI_D6 - - - - EVENTOUT
38 JMISC PE8 - TIM1_CH1N - - - - MDF1_CKI2 - - - - - FMC_D5/FMC_
AD5
SAI1_SCK_B - EVENTOUT
39 JMISC PI7 - - - TIM8_CH3 - OCTOSPIM_
P2_NCLK
- - - - DCMI_D7/PSSI_D7 - - - - EVENTOUT
40 JMISC PF14 - - - - I2C4_SCL - - - - TSC_G8_IO1 - - FMC_A8 - - EVENTOUT
41 JMISC PD9 - - LPTIM2_IN2 - - - - USART3_RX - - DCMI_PIXCLK/
PSSI_PDCK
- FMC_D14/FMC
_AD14
SAI2_MCLK_A LPTIM3_IN1 EVENTOUT
42 JMISC PF15 - - - - I2C4_SDA - - - - TSC_G8_IO2 - - FMC_A9 - - EVENTOUT
43 JMISC PI5 - - - TIM8_CH1 - OCTOSPIM_
P2_NCS
- - - - DCMI_VSYNC/
PSSI_RDY
- - - - EVENTOUT
44 JMISC PA3 - TIM2_CH4 TIM5_CH4 SAI1_CK1 - - - USART2_RX LPUART1_RX - OCTOSPIM_P1_CLK LPGPIO1_P1 - SAI1_MCLK_A TIM15_CH2 EVENTOUT
45 JMISC PD8 - - - - - - - USART3_TX - - DCMI_HSYNC/
PSSI_DE
- FMC_D13/FMC
_AD13
- - EVENTOUT
46 JMISC PA0 - TIM2_CH1 TIM5_CH1 TIM8_ETR - - SPI3_RDY USART2_CTS UART4_TX - OCTOSPIM_
P2_NCS
- SDMMC2_CMD AUDIOCLK TIM2_ETR EVENTOUT
47 JMISC PA8 MCO TIM1_CH1 - SAI1_CK2 - SPI1_RDY - USART1_CK - - OTG_FS_SOF - TRACECLK SAI1_SCK_A LPTIM2_CH1 EVENTOUT
48 JMISC PA1 LPTIM1_CH2 TIM2_CH2 TIM5_CH2 - I2C1_SMBA SPI1_SCK - USART2_
RTS/USART2_
DE
UART4_RX - OCTOSPIM_
P1_DQS
LPGPIO1_P0 - - TIM15_CH1N EVENTOUT
49 JMISC PA10 CRS_SYNC TIM1_CH3 LPTIM2_IN2 SAI1_D1 - DCMI_D1/PSSI_D1 - USART1_RX - - OTG_FS_ID - - SAI1_SD_A TIM17_BKIN EVENTOUT
I will probably update them soon to mention on which pin on JMISC it is actually on...
Ventuno is the Italian word for 21. The name references the fact that 2026 is Arduino's 21st anniversary.
To that I offer a toast. Congratulations on 21 years.
Thank you for sharing post #12.
You are welcome.
Still wondering when this will be released. Guessing it might be when the new Bigger Q comes out, along with an update ArduinoCore-zephyr/zephyr release that has more functionality, like DCMI enabled or ... But again just guessing
