anyone familiar with high speed constant servo?
Hi there,
I am using a high speed constant servo but I cannot control it properly.
What I want to do is that:
send a '1', let it turn clockwise for like 5 seconds, then stop;
send a '2', let it turn anticlockwise for 5s, then stop;
send a '0', stop it.
Following is my code (not decent enough), It can only stop when I put a '0' in Serial, is there any way for me to stop it after 5s-rotation?
Thanks a lot!
#include <VarSpeedServo.h>
//Look at Servo library. A continuous rotation servo will need to be set
//at approx 90 degrees to stop. 0 will turn one direction and 180 the other.
//There will be some deadband around 90 and the speed will be faster as you
//give it a value farther from 90.
//initiate
VarSpeedServo myservo;
int pos = 0;
int servoPin = 9;
int ledPin = 3;
//conncect to processing
char val;
//replace delay
unsigned long currentTime;
unsigned long previousTime = 0;
unsigned long servoCurrentTime;
unsigned long servoPreviousTime;
int interval = 1000;
int servoInterval = 10;
  //led
  pinMode(ledPin, OUTPUT);
  //  servo
  myservo.attach(servoPin);
  myservo.write(94, 1, true); //reset position
  currentTime = millis();
  servoCurrentTime = millis();
  //delay for Serical.read();
  if (currentTime - previousTime >= interval  && Serial.available())
    previousTime = currentTime;
    val = Serial.read ();
  if (val == '1') {
    digitalWrite(ledPin, LOW);
    for (int pos = 0; pos < 94; pos ++)       // clockwise
      if(servoCurrentTime - servoPreviousTime > servoInterval)
      servoPreviousTime = servoCurrentTime;
      myservo.write(pos, 10, true);
      Serial.println(myservo.read());
  } else if (val == '2') {
    digitalWrite(ledPin, HIGH);
    for (int pos = 180; pos < 190; pos++) //anticlockwise
  } else if (val == '0') {
        myservo.write(94, 10, true);
[code][code][code]
[/code][/code][/code]
Yes, add a separate test in loop () for wheter 5 seconds has elapsed. The test for Serial.available is
an independent event, you cannot use a single if.
MarkT:
Thanks, i have modified my serial.available sentence, but when I try to stop motor after 3 seconds, it dose not work. I wonder what is wrong with my code this time....
if (val == '1') {
if(//whaaaaaaaaaaat?)
myservo.write(pos, 50, true);
else if (servoPreviousTime>=3000) //dose not work??????
Please post all of your code,not just a section.
Before posting PLEASE in the IDE, select TOOLS then Auto-Format.
It will help with the indenting of your loops and if statements.
Then post it, DON'T forget the code tags.
Thanks.. Tom.. :slight_smile:
I just meant change
to
  if (timing && currentTime - start_time >= TIMEOUT)
     // handle timout
     timing = false ;
     motor_stop () ;
  if (Serial.available () > 0)
    val = Serial.read () ;
    // handle char, such as starting motor, setting up timer
so that both conditions are handled independently as they are independent events.
Setting up the timer is just:
  timing = true ;
  start_time = millis () ;
