I want to have a list of 20 or more preset passwords that would work to open a lock with an ir remote.
I have code to compare an entered password by ir remote to a single preset password, but I need multiple preset passwords that would work.
This is essentially what I want to do in the picture, but I want to remove the keypad altogether because I do not want it to set a password or to enter the password. I want to have preset passwords (like "1234567") I can set by modifying the code itself. I want to be able to enter the password with the ir remote. Code starts below.
#include <Keypad.h>
#include <LiquidCrystal.h>
#include <IRremote.h>
LiquidCrystal lcd(A5, A4, A3, A2, A1, A0); // set pin to LCD
IRrecv rCode(10); //set pin 10 for remote code
decode_results remoteCode; //var for write code
const byte ROWS = 4; //4 rows of keypad
const byte COLS = 4; //4 columns of keypad
char pressKey;
char Keys[ROWS][COLS] = { //symbol's of keypad
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
// * as open lock, # as set psw and close lock
byte rowPins[ROWS] = {9,8,7,6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5,4,3,2}; //connect to the column pinouts of the keypad
Keypad cKeypad = Keypad( makeKeymap(Keys), rowPins, colPins, ROWS, COLS); // init keypad
int enderClose=12; //pin for ender switcher (when lock is closing)
int enderOpen=13; //pin for ender switcher (when lock is opening)
int motor=11; //pin for lock motor (closing/opening)
bool locked=false; // variable for lock satus
String code=""; // variable for entering unlock code
String codeLock=""; // variable for entering lock code
///////////////////////setup sketch//////////////////////////////////////////
lcd.begin(16, 2); //set size of LCD (16 symb of 2 rows)
rCode.enableIRIn(); //enable IR
rCode.blink13(true); //i don't know this
pinMode(enderClose, INPUT); //pin ender switcher as input
pinMode(enderOpen, INPUT); //pin ender switcher as input
pinMode(motor, OUTPUT); //pin motor as output
digitalWrite(motor, LOW); //beginning satatus of motor
//Serial.begin(9600); //setting foe seral monitor
/////////////////// opening lock by motor /subprogramm///////////////////////////
void openLock()
digitalWrite(motor, HIGH); //ON motor
while (digitalRead(enderOpen)==HIGH) {}; // wait for ender swicher opening
digitalWrite(motor, LOW); //OFF motor
//delay(100);
/////////////////// closing lock by motor /subprogramm/////////////////////////////////
void closelock()
while (digitalRead(enderClose)==HIGH) {}; // wait for ender swicher closing
//delay(100);
////////////////// read unlock code by keypad /subprogramm////////////////////////
void readKeyPadCode()
String _code=""; //local variable for entring temp unlock code
int _i=0; //local variable for count of symbol
while (true) // repeat until force exit
pressKey = cKeypad.waitForKey(); //wait press key and write she to variable
/Serial.println("key pressed is- "+pressKey);
delay(30);/
if ((pressKey=='')&&(_i==0)) //If press "" (enter code) and no one symbol
lcd.setCursor(0,1); //begin on second line
lcd.print("PSW is Empty "); //show on LCD password is empty
continue; //jump to begin of "while"
if ((pressKey=='')&&(_i!=0)) // if pressed "" (enter code) and have a symbol/simbols
code=_code; // assign unlock code from local temp code
/Serial.println("Enter code is- "+code);
delay(30);/
pressKey=0; // reset value of press key variable
break; //force exit from "while"
_code=_code+pressKey; //add to temp unlock code last symbol
/Serial.println("Temp code is- "+_code);
delay(30);/
lcd.setCursor(_i,1); //move cursor LCD to next position
lcd.print("#"); //show on LCD "#" ("#","##","###"...)
_i++; //increment _i
This could be removed and replaced with predefined passwords that would allow you to open the lock
///////////////////// setup password by keypad /subprogramm/////////////////////////
void setKeyPadCode()
String _ccode=""; //local variable for entring temp unlock code
int _j=0; //local variable for count of symbol
if ((pressKey=='#')&&(_j==0)) //If press "#" (enter password) and no one symbol
if ((pressKey=='#')&&(_j!=0)) // if pressed "#" (enter password) and have a symbol/simbol
codeLock=_ccode; // assign lock code from local temp code
if (pressKey=='') continue ; //ignore symbol '' by entring code
lcd.setCursor(_j,1); //move cursor LCD to next position
_ccode=_ccode+pressKey; //add to temp unlock code last symbol
delay(30);
Serial.println("temp code is- "+_ccode);
delay(30);/
_j++; //increment _j
/Serial.println("PSW setup is- "+codeLock);
delay(30);/
locked=true; //status of lock
lcd.setCursor(0,1); //setup cursor to beginning first line
lcd.print("PSW is set "); //show on LCD password is set
//////////////////////// read unlock code by IR-reciver /subprogramm////////////////////
void readIRRCode()
String _str=""; //local variable for entring temp unlock code
char _key=0; //local variable for symbol of IR decode
bool _isNum=false; //local variable for number status of code
unsigned long _code_value = 0; //local variable for IR decode
if (rCode.decode(&remoteCode)) // do it if recive IR code
_code_value=remoteCode.value; //decode IR code
if ((_code_value==0xFD708F)&&(_i==0)) //If pressed "ST/REPT" (enter password) and no one symbol
lcd.setCursor(0,1); //setup cursor to beginning second line
rCode.resume(); //need for resume to recive IR code
if ((_code_value==0xFD708F)&&(_i!=0)&&(_key!=0))
{ // if pressed "ST/REPT" (enter password) and have a symbol/simbol
code=_str; // assign unlock code from local temp code
/Serial.println("recive IR ST/Rept");
delay(30);
Serial.println("recive code is- "+code);
delay(30);/
_key=0; // reset value of key code variable
switch (_code_value) //select of decode value of recive code
case 0xFD30CF: //if 0
_key='0'; // assign IR decode and zero
_isNum=true; // enter code is number
break ;
case 0xFD08F7: //1 (see here and next as 0)
_key='1';
_isNum=true;
break ;
case 0xFD8877: //2
_key='2';
_isNum=true;
break ;
case 0xFD48B7: //3
_key='3';
_isNum=true;
break ;
case 0xFD28D7: //4
_key='4';
_isNum=true;
break ;
case 0xFDA857: //5
_key='5';
_isNum=true;
break ;
case 0xFD6897: //6
_key='6';
_isNum=true;
break ;
case 0xFD18E7: //7
_key='7';
_isNum=true;
break ;
case 0xFD9867: //8
_key='8';
_isNum=true;
break ;
case 0xFD58A7: //9
_key='9';
_isNum=true;
break ;
default: //if not a number
_isNum=false; //variable status as no number
if (_isNum==true) //do it if recive number
_str=_str+_key; //assign temp code and recive symbol
/Serial.println("recive IR is- "+_key);
delay(30);
Serial.println("temp code is- "+_str);
delay(30);/
_i++; //increment symbol count
} //end of first "if"
} //end of "while"
} //end of "void"
////////////////////// main programm body//////////////////////////
if (locked==false) // do it if lock status is unlock ("open")
lcd.setCursor(0,0); //setup cursor to beginning first line
lcd.print("Lock is unlocked"); //show on LCD "Lock is unlocked"
lcd.print("Input Code & # "); //show on LCD "Input Code & #"
setKeyPadCode(); //if lock unlocked need set password. Calling subprogramm
closelock(); //lock after enter password. Calling subprogramm
lcd.print("Lock is locked "); //show on LCD "Lock is locked"
locked =true; // set lock status as "loked"
if (locked==true) //do it if lock status is lock ("close")
if (cKeypad.getKey()!=NO_KEY) //do it if enter code on keypad
readKeyPadCode(); //if lock is locked need enter code. Calling subprogram
if (code==codeLock) //do it if entring code equal with password
openLock(); //unlocking lock. calling subprogramm
locked=false; // set lock status as "unloked"
codeLock=""; // reset value of password
} else //do it if entring code not equal with password
lcd.print("PSW is invalid "); //show on LCD "password is invalid"
if (rCode.decode(&remoteCode)) //do it if enetr code on IR-remote control
readIRRCode(); //if lock is locked need enter code. Calling subprogramm
} else
///////////////////////end sketch ////////////////////////////////
