Please help me out about what happen to the display?
Why there has garbled character after 6cm?
After few runs the display comes out many garbled characters then frozen.
#include <NewPing.h>
#include <LiquidCrystal.h>
#define TRIGGER_PIN 8
#define ECHO_PIN 9
#define MAX_DISTANCE 200
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
lcd.begin(16, 2);
lcd.clear();
unsigned int uS = sonar.ping();
lcd.print("Ping: ");
lcd.print(sonar.convert_cm(uS));
lcd.println("cm");
lcd.clear();
Zapro
2
Did you ground the C/D-pin on the display?
Show us a schematic.
// Per.
Zapro:
// Per.
The display connection I just follow the book and do some modification hide some cables under the display.
According to your code:
I assume your LCD control pins is the same as Hello World demo program. listed as below:
The circuit:
- LCD RS pin to digital pin 12
- LCD Enable pin to digital pin 11
- LCD D4 pin to digital pin 5
- LCD D5 pin to digital pin 4
- LCD D6 pin to digital pin 3
- LCD D7 pin to digital pin 2
- LCD R/W pin to ground
- LCD VSS pin to ground
- LCD VCC pin to 5V
- 10K resistor:
- ends to +5V and ground
- wiper to LCD VO pin (pin 3)
so, I think you need connect LCD module pin 5 (R/W) to GND, and in you vedio YOUR E pin should connect to LCD module pin 6, not pin7 D0!
chincheng:
The circuit:
- LCD VCC pin to 5V
- 10K resistor:
You're right. My E pin connected to 7. Thanks
The frozen issue has been fixed after I switch the E pin back to 6.
However, still has that garbled character after the world "cm".
Did you connect R/W pin to GND?
Chnage the lcd.println("cm"); to lcd.print("cm");
chincheng:
WOW. All fixed. Thank you.
