Anyone knows how to change this to work with 3 integers instead?
// Example 5 - Receive with start- and end-markers combined with parsing
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];        // temporary array for use when parsing
      // variables to hold the parsed data
char messageFromPC[numChars] = {0};
int integerFromPC = 0;
float floatFromPC = 0.0;
boolean newData = false;
    Serial.println("This demo expects 3 pieces of data - text, an integer and a floating point value");
    Serial.println("Enter data in this style <HelloWorld, 12, 24.7>  ");
    recvWithStartEndMarkers();
    if (newData == true) {
        strcpy(tempChars, receivedChars);
            // this temporary copy is necessary to protect the original data
            //   because strtok() used in parseData() replaces the commas with \0
        parseData();
        showParsedData();
        newData = false;
void recvWithStartEndMarkers() {
    static boolean recvInProgress = false;
    static byte ndx = 0;
    char startMarker = '<';
    char endMarker = '>';
    char rc;
    while (Serial.available() > 0 && newData == false) {
        rc = Serial.read();
        if (recvInProgress == true) {
            if (rc != endMarker) {
                receivedChars[ndx] = rc;
                ndx++;
                if (ndx >= numChars) {
                    ndx = numChars - 1;
            else {
                receivedChars[ndx] = '\0'; // terminate the string
                ndx = 0;
                newData = true;
        else if (rc == startMarker) {
            recvInProgress = true;
void parseData() {      // split the data into its parts
    char * strtokIndx; // this is used by strtok() as an index
    strtokIndx = strtok(tempChars,",");      // get the first part - the string
    strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
    strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
    integerFromPC = atoi(strtokIndx);     // convert this part to an integer
    floatFromPC = atof(strtokIndx);     // convert this part to a float
void showParsedData() {
    Serial.print("Message ");
    Serial.println(messageFromPC);
    Serial.print("Integer ");
    Serial.println(integerFromPC);
    Serial.print("Float ");
    Serial.println(floatFromPC);
Original Code from here
I am trying to communicate my Arduino with ESP32. Now the last part left is to make the values obtained in Arduino send over to ESP32 and make the values a variable so they can be read by Arduino IoT Cloud. I searched for solutions. However, the best solution is what I found on this thread, which then led me to the code above. I am a beginner, so I am very sorry for my incompetence.
Thank you!
talk to @errols ...
if you are sure you are receiving 3 data, just add one
and use something like
to extract the data
You mean 3 integers instead of 1 string, 1 integer and 1 float?
If so, I think the code you have found was purposely written to provide examples of each of those 3 kinds of values. It currently reads the message to extract an integer, you just need to do that 3 times.
But if you are a beginner, this is not the best way to start. It's too complex and confusing. Start with simple tutorials that flash LEDs etc. You need to understand the basics of programming in C before tackling something like this.
consider
char s [80];
#define MaxTok  10
char *toks [MaxTok];
int   vals [MaxTok];
int
tokenize (
    char       *s,
    const char *sep )
    unsigned n = 0;
    toks [n] = strtok (s, sep);
    vals [n] = atoi (toks [n]);
    for (n = 1; (toks [n] = strtok (NULL, sep)); n++)
    return n;
void dispToks (
    char * toks [])
    char s [40];
    for (unsigned n = 0; toks [n]; n++)  {
        sprintf (s, " %6d  %s", vals [n], toks [n]);
        Serial.println (s);
void loop ()
    if (Serial.available ())  {
        int n = Serial. readBytesUntil ('\n', s, sizeof(s)-1);
        s [n] = 0;      // terminate string
        tokenize (s, ",");
        dispToks (toks);
void setup ()
    Serial.begin (9600);
Thank you everyone for the help! I found the solution that I wanted it is from this site. The code for breaking up a single string into different variables are as follows:
if(Serial.available()){
  String rxString = "";
  String strArr[2]; //Set the size of the array to equal the number of values you will be receiveing.
  //Keep looping until there is something in the buffer.
  while (Serial.available()) {
    //Delay to allow byte to arrive in input buffer.
    delay(2);
    //Read a single character from the buffer.
    char ch = Serial.read();
    //Append that single character to a string.
    rxString+= ch;
  int stringStart = 0;
  int arrayIndex = 0;
  for (int i=0; i < rxString.length(); i++){
    //Get character and check if it's our "special" character.
    if(rxString.charAt(i) == ','){
      //Clear previous values from array.
      strArr[arrayIndex] = "";
      //Save substring into array.
      strArr[arrayIndex] = rxString.substring(stringStart, i);
      //Set new string starting point.
      stringStart = (i+1);
      arrayIndex++;
  //Put values from the array into the variables.
  String value1 = strArr[0];
  String value2 = strArr[1];
  //Convert string to int if you need it.
  int intValue1 = value1.toInt();
I studied and changed the code to like this:
String value1,value2,value3,value4,value5;
char ch;
int aqi,co;
float temp,hum;
 if(Serial2.available()){
  String strArr[4]; //Set the size of the array to equal the number of values you will be receiveing.
  while (Serial2.available()) {
    delay(2);
    ch = Serial2.read();
    rxString+= ch;
  int arrayIndex = 0;
      arrayIndex++;
  value1 = strArr[0];
  value2 = strArr[1];
  value3 = strArr[2];
  value4 = strArr[3];
  value5 = strArr[4];
  aqi = value1.toInt();
  co = value2.toInt();
  temp = value3.toFloat();
  hum = value4.toFloat();
I am still a bit new to this. The solution provided by gcjr and J-M-L doesnt seem to work for me. Moreover, I am not familiar with the code, I dont even know like 80% of the code even does lol. Therefore, I found the next solution. I think that this solution is better for begineers like me and the code is easier to understand, I manged to tweak them by myself.
Anyways I hope it helps other people in the future! I am not a native English speaker, hopefully you guys can understand my english. Thank you very much!
