Anyone want to have a crack at converting Adafruit's Flying Toasters for TVout?
Adafruit has a tutorial on how to display the classic Flying Toasters screensaver on an OLED display.
I wanted to have a go at converting it to display on a CRT with the TVout library.
So far I have this, but I just get a few blips on the screen. Not sure what to fix. I'm trying to change it to work with the TVout's 128x96 resolution.
I'm using Arduino 1.0.4 or that Robot Controller bug creeps in.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <TVout.h>
#include "bitmaps.h" // Toaster graphics data is in this header file
TVout TV;
#define N_FLYERS   5 // Number of flying things
struct Flyer {       // Array of flying things
  int16_t x, y;      // Top-left position * 16 (for subpixel pos updates)
  int8_t  depth;     // Stacking order is also speed, 12-24 subpixels/frame
  uint8_t frame;     // Animation frame; Toasters cycle 0-3, Toast=255
flyer[N_FLYERS];
uint32_t startTime;
  TV.begin(NTSC, 120, 96);
//randomSeed(analogRead(2));           // Seed random from unused analog input
  randomSeed(100);           // Seed random from unused analog input
  for(uint8_t i=0; i<N_FLYERS; i++) {  // Randomize initial flyer states
    flyer[i].x     = (-16 + random(10)) * 10;
    flyer[i].y     = (-16 + random( 10)) * 10;
    flyer[i].frame = random(3) ? random(4) : 255; // 66% toaster, else toast
    flyer[i].depth = 10 + random(12);             // Speed / stacking order
  qsort(flyer, N_FLYERS, sizeof(struct Flyer), compare); // Sort depths
  startTime = millis();
  uint8_t i, f;
  int16_t x, y;
  boolean resort = false;     // By default, don't re-sort depths
  TV.clear_screen();
  for(i=0; i<N_FLYERS; i++) { // For each flyer...
    // First draw each item...
    f = (flyer[i].frame == 255) ? 4 : (flyer[i].frame++ & 3); // Frame #
    x = flyer[i].x / 12;
    y = flyer[i].y / 12;
    TV.bitmap(x, y, (const uint8_t *)pgm_read_word(&mask[f]), 32, 32, BLACK);
    TV.bitmap(x, y, (const uint8_t *)pgm_read_word(&img[ f]), 32, 32, WHITE);
    // Then update position, checking if item moved off screen...
    flyer[i].x -= flyer[i].depth * 2; // Update position based on depth,
    flyer[i].y += flyer[i].depth;     // for a sort of pseudo-parallax effect.
    if((flyer[i].y >= (64*12)) || (flyer[i].x <= (-32*16))) { // Off screen?
      if(random(7) < 5) {         // Pick random edge; 0-4 = top
        flyer[i].x = random(120) * 12;
        flyer[i].y = -32         * 12;
      else {                    // 5-6 = right
        flyer[i].x = 128         * 12;
        flyer[i].y = random(64)  * 12;
      resort = true;
// Flyer depth comparison function for qsort()
static int compare(const void *a, const void *b) {
  return ((struct Flyer *)a)->depth - ((struct Flyer *)b)->depth;
Not sure how to fix
Here's the original code: Code | Animated Flying Toaster OLED Jewelry | Adafruit Learning System
