Using the Arduino_APDS9960 library, I found that I needed to call APDS.begin() again before the color sensor reads started working.
Interestingly, a FullExample example sketch was added in the latest 1.0.3 release of the library that demonstrates the gesture, color, and proximity features all being used in the same sketch. If you remove the proximity sensor code then the color sensor readings stop working so there is something wrong with the library that makes it only work correctly in the specific configuration of the FullExample sketch. I notice that even to get that working, they had to fix a bug in the library:
so I suspect something similar needs to be extended to the color sensor code. I had a look at the library code, but I am having trouble figuring out exactly what would need to be done. Well, at least it works fine with the workaround of calling APDS.begin() again so it's not so bad.
#include <Arduino_APDS9960.h>
bool gestureDetected = false;
while (!Serial);
if (!APDS.begin()) {
Serial.println("Error initializing APDS9960 sensor!");
Serial.println("Waiting for gesture");
if (APDS.proximityAvailable()) {
APDS.readProximity();
switch (gestureDetected) {
case false:
if (APDS.gestureAvailable()) {
// a gesture was detected, read and print to serial monitor
int gesture = APDS.readGesture();
gestureDetected = true;
APDS.begin(); // this is required to enable the color sensor after using the gesture sensor
switch (gesture) {
case GESTURE_UP:
Serial.println("Detected UP gesture");
case GESTURE_DOWN:
Serial.println("Detected DOWN gesture");
case GESTURE_LEFT:
Serial.println("Detected LEFT gesture");
case GESTURE_RIGHT:
Serial.println("Detected RIGHT gesture");
default:
// ignore
case true:
if (APDS.colorAvailable()) {
int r, g, b;
// read the color
APDS.readColor(r, g, b);
// print the values
Serial.print("r = ");
Serial.println(r);
Serial.print("g = ");
Serial.println(g);
Serial.print("b = ");
Serial.println(b);
