I recently tried to help somebody out on the forum and some of the information I posted was incorrect. Is there a way of applying a strikeout to the incorrect text or otherwise somehow marking it as such?
[s]message[/s]
message
Applying strikeout to text in a post is as easy as adding HTML <strike>
tag to the text you want to strikeout.
Applying strikeout to text in a post is as easy as adding strike
Thanks Chris. I was looking at the menu icons whilst editing the post but couldn't see anything.
I wonder if there are any more "hidden" formatting options as it were?
@ninora , so we can insert HTML into our text as another option?
Or use ~~ ~~
~~message~~
message
The Arduino forum now supports three different markup languages:
So there are multiple ways to accomplish most formatting goals.
My preference is to use Markdown because it is the most straightforward and, due to being one of the most popular markup languages, a familiarity with Markdown is also beneficial at many other times.
https://www.markdownguide.org/extended-syntax/#strikethrough
I tried it here for the first time and it worked so I guess you can add
some tags
while other are filtered outI tried it here for the first time and it worked so I guess you can add <h3>some tags</h3> while other <span style="background-color:red;">are filtered out</span>
You can avoid the ; termination from style string for do that.
BLOODY
<span style="background-color:red">BLOODY</span>
Cool ![]()
