I've read up a bit on batteries to power the arduino UNO, particularly the poor quality of standard 9 volt batteries. It surprises me after reading this that people continue to advise using these batteries in their projects.
A truck battery + DC 5V converter will last quite a long time.
Though the question was posed inaccurate, I think the general idea was clear: In a common portable way, with easy to acquire parts. I would think this means either one or more AA batteries or or a 3.7V LiPo.
So, I do not have a good answer, but perhaps a few question and thoughts that lead us further.
Regarding AA:
4 Eneloop give 4.8-5.4V. Is it advisable to feed that to an Arduino 5V PIN directly? Is there an effective way (that works with Arduino sleep without draining the battery further) to get the 5.4V down? Is there an effective way to at least protect everything from the 6V of non-rechargeable batteries?
For lower voltages, an IC is proposed in the link above, the LTC3525, however it is rated for relatively low currents. Are there stronger alternatives? 100-150mA is at least not enough for an ESP8266. I don't know about the nrf24l01 or cheap 433MHz modules.
What are the possibilities for higher voltages?
What is the best way to avoid decharging the rechargeable s too much?
So, what is the advised way for a compact, long lasting (that is, using sleep mode) mobile Arduino? If not anyway, what are the most beginner friendly/low quantity alternatives (for example, the module mentioned above, no SMD soldering ...)
I often use 3xAAA with a DC boost and USB cable (power goes in through USB port).
ElCaron:
But as soon as you say "sleep mode" then that method doesn't work (and neither does a standard Arduino).
So, no, your "general idea" was not clear. Not really.
The only way for really long sleep mode is direct battery power+bare chip. No regulators, no DC converters, no Arduino Unos.
PS: Arduinos/ATMega chips will work with a less than 5V but you must never give them more than 5V. 4 freshly charged Eneloops might give you 6V for a few minutes.
What is "that method"? Your board? Or the proposed IC? The LTC3525 draws around 0.05-0.1mW when under almost no load. With 2 AA Eneloops, this would run for more than 5 years. What ius wrong with a standard Arduino? Arduino Playground - HomePage only mentions the ineffective 7805 power regulator, but bypassing that is one of the big points of this thread.
I am not the original poster, so it wasn't my idea anyway.
The Amtel data sheet lists a maximum voltage of 5.5V. If it is only for the first few minutes (and thus the loss is acceptable), perhaps a 5.4V Zener diode could limit the voltage during that time without being inacceptably inefficient..
elac:
I would get this charger over the one you linked to.
I see that one has the same chip, but separated battery/output contacts. What do they give you? A regulated voltage? Which one? Do you know at which efficiency?
If you really want to use sleep mode and have the circuit function as long as possible on batteries, then do what everyone else does. Skip the voltage regulator, use 3V batteries (e.g. 2 AA or AAA alkaline) and design all the circuitry to work with a variable voltage ranging from about 3.2 V down to 2.5 V or so. This is the industry standard practice for remote sensors, clocks, some toys, etc.
Alkaline batteries have storage times of 10 years or so, while NiCd, NiMH and LiPo batteries discharge themselves at rates you can look up.
The one you quoted: 3xAAA with a DC boost.
ElCaron:
Sure, but "almost no load" isn't the same as "no load". If you have to apply any load at all to keep it alive then you're draining the battery for no good reason.
For comparison: A bare AVR chip with a battery will easily run under 10uA power draw. I've built things that run for years on a single coin cell.
(I don't know exactly how many years, I'm still waiting for the battery to die. It's currently at 1.8 years, and counting...)
ElCaron:
The Uno (for example) has a second ATMega chip on the board that can't be put to sleep.
ElCaron:
Perhaps. It all depends on what battery life you actually need, what's connected to the Arduino, etc.
The point still stands: "How long is a piece of string?"
There's no general answer to the original question. "Truck battery with DC step-down" is as good an answer as without an exact specification.
(The only thing we can all agree on is that 9V PP8 batteries are crap).
fungus:
I've never had an Eneloop charge over 1.46V/cell. 5.84V is on the edge of the 6.0V rated maximum (see page 313 of the datasheet), but I think you could get away with it. But if your Eneloops ever died at an inopportune moment, you might be tempted to pop some alkalines in... a 5.6V Zener for such cases seems like a reasonable safety measure.
If you intend to use alkalines all the time, then a 3-cell holder is the way to go.
So yeah, a 3/4-cell holder seems like a low-cost low-hassle replacement for a PP3 square 9V battery. I mean, if you were previously using a PP3, you're not worried about year-long sleep modes anyway. You're just looking for a convenient way to power your Uno away from a wall wart. A 3/4-cell holder is it.
How do I implement battery control and undercharge protection in that case? I mean, I am lacking a reference voltage, don't I?
ElCaron:
AVR chips have built-in voltage references. You could switch off all external devices and go into deep sleep when the battery reaches a certain voltage.
Or just use a prebuilt battery charger circuit. They're cheap, do over/under protection, and you can charge your device by connecting it to a USB socket without removing the batteries.
fungus:
Oh, I see. The Arduino Reference says that the internal reference is 2.56V. Does that mean that 2.56V on n analog pin then give a read of 1023? would 5V then be a problem, if the board is also powered with that voltage?
Apart from that, I am struggling a little with "design your circuit so it runs with the voltage range of the battery" ... The ESP8266 (ESP8266 - NURDspace) for example doesn't seem to take the highest voltages of a LiPo.
Any suggestions how to power an ATMega/Arduino+ESP8266 with a LIPO so it can SLEEP/IDLE for at least a few month?
fungus:
It depends on the chip. eg. A Tiny85 has 1.1V and 2.65V references, a Mega328 only has a 1.1V reference....
ElCaron:
Yes, but you don't do it that way because Vcc is normally higher than the internal reference (ie. you'll always get a reading of 1023).
What you do is use Vcc as Aref then measure the internal 1.1V reference voltage. The rest is math.
