Ardiuno Serial RW from Tera Term
Hi All,
I'm trying to make a program that it reads from serial and replies.
If I use Ardiuno IDE > Tools > Serial Monitor it reads line and replies to the commands.
But if I use Tera Term it only reads one character at a time.
Here's my code:
#define CMDBUFFER_SIZE 32
String readString;
  Serial.println("Ardiuno Started");
  Serial.setTimeout(3);
    while(Serial.available())
    delay(3);
    readString = Serial.readStringUntil('\n');
  if(readString.length()>0)
    Serial.print("First String is ");
    Serial.println(readString);
    if(readString == "AT" || readString == "at")
      Serial.println("OK");
    else if (readString == "AT+RESET" || readString == "at+reset")
      Serial.println("Resetting the device");
    else if(readString == "AT+RANDOM" || readString == "at+random")
      for (int i = 0; i < 300; ++i)
        int randInt = random(300);
        Serial.println(randInt);
        delay(50);
      Serial.println("No Command Found");
    readString = "";
How can I configure my code or environment to achieve communicate from Tera Term?
The problem lies in the fact Serial Monitor is a pretty janky 'pretend' serial terminal.
PuTTY or TeraTerm are far better options, because they let you configure the serial stream and terminal parameters individually - as well as sending each character as it's typed.
Typically, you would receive each character individually, then accumulate those into a straing - when CR or LF is received you can parse that complete string to identify your command as needed.
The benefit or processing character by character - is that you can respond to individual 'special characters' to perform 'special' actions... like BACKSPACE, ESCAPE, TAB and RETURN - among others.
You have two choices:
  1. Configure terminal for character echo and program simply accepts characters.
  2. Configure terminal for no echo, and have the program echo everything it receives.
An over simplification because in a mature implementation, some control characters aren't echoed.
I prefer application controlled echo because it doesn't send "blindly". The characters you see must have been received and processed.
