I want to send datas from my nano to my android device(Alcatel Pop C7) using USB. I downloaded AndroidHyperTerminal from Google Play to test the serial communication but my Phone didn't see my nano.I tryed other apks witch supported the FT232RL chip but none of them detects the adapter :~
I use this in the arduino side to test the serial communication:
int led = 13;
pinMode(led,OUTPUT);
digitalWrite(led,HIGH);
digitalWrite(led,LOW);
Serial.println(1);
In win7 x64 works fine.The Phone and the OTG function works too.
Pls help me, what am i doing wrong?
I think that this thread is in the wrong place. But, my first thought was "USB OTG", but as you say that you have it, my second hypotheses is "drivers". Did the android have drivers to "see" and communicate with an Arduino board?
I saw the video. And I remember to ask: when you say "The Phone and the OTG function works too" you means that you have the cable USB OTG and your phone supports host mode, right?
Android always have drivers for dealing with the Serial protocol on the usb its just that they may not be accessible without deep trodden rooting sometimes of the phone!
NI$HANT:
contact me if you may want it done.
Why would you need to root your android device in order to use the USB port with a USB-> serial adapter and what is "Deep Trodden" rooting as opposed to plain old rooting ? I am confused .
Because every Android kernel won't give access to its drivers down under which are not to be utilised normally, I have done this several times with Android devices at my disposal, they dont have serial port emulated without rooting.
Rooting is always Deep Trodden never plain old as such.
That is interesting , every android device that I have use OTG USB interfacing with does not require "rooting" Admittedly I have only tried connecting FDTI chipset based USB-> serial bridge hardware but never had to root my device to gain access to it.
How do the applications in the android store do this without root access. Perhaps I have been lucky with my choice of hardware. I am not suggesting that it is never required. That would depend on the manufacturers choice on accessibility of the core systems. That said however I have not so far found any devices that would stop me gaining access to the USB.
There is no such thing as deep trodden rooting, rooting is rooting or according to WIKI ( Rooting (Android) - Wikipedia ) gaining access to the kernel of the OS with administrator rights. There are no levels of rooting, Deep Trodden or otherwise mentioned.
Could you give me an example of Deep Trodden routing. I am learning this as i go along and any knowledge would be useful.
Deep trodden rooting means rooting only, its just the way to put it forward and may include bootloader unlocking because if you can understand rooting ,rooting means getting deep into the realms that are not controllable else you root the device, Hence rooting is always Deep Trodden.
"That you have used" this is something not to explain here OTG devices are OTG devices that have Host controller chipset they are found in new versions ,there are tons of Android devices without any OTG support what about those and Even in the case of some OTG supporting devices there is still need to root the phone and get the access to the specific functionality in the Kernel, a classic example to this are 2 year old phones from now, I have 2 of these which support USB OTG only after rooting and which also emulate Serial ports only after rooting and without Serial port emulation whom you are going to talk with, phones ass maybe.
Many of the Apps on the Android store don't work with unrooted phones and some work they work with high end devices which have OTG, you need to read the description of these apps in detail.
The fact that many USB host controller apps, stick mount apps require rooting, thats very common requirement called from such apps.
Ahhh OK so "Deep Trodden" is just something that you made up and does not actually exist, thanks for clearing that up.
I do believe that most new devices on the market these days do have OTG support .
perhaps you missed the post where the OP said .......
Yes i have an OTG cable and my phone support the USB Host mode. I can connect pendrives,mouses,keyboards and controllers to it.
So I guess it does not need (Deep Trodden) rooting.
Its nothing I made up I have the right to put my ideas in my way, along what I said read it deeply, I also said Bootloader unlocking now that's deep trodden.
I talk universal solution.
Read my statements carefully I said it "may" need rooting and again READ WHAT I POST CAREFULLY BEFORE MAKING REMARKS I told you about some old phones that I worked with already have OTG support but weren't still emulating serial ports until unless I rooted them so Hence rooting "maybe" required.
NI$HANT:
Yes it is there is no such thing as "Deep Trodden" rooting. I Simply asked you to explain what that meant and you said "it just means rooting", therefor you made it up. I am not suggesting that coining expressions is a bad thing but your terms are a little confusing.
NI$HANT:
Now shouting is just plain rude, but in keeping with the tone of your responses , so I am not surprised.
I suggest that you take a leaf out of your own book and read the post and its thread before posting. especial in light of the fact that you said that rooting is done to gain access to the USB port but the OP clearly states that he has this already.
You seem to be being very defensive about this, I am not sure why. All I asked for was clarity on your original post which was confusing and using self invented expressions.
I EMPHAZIZED and not shouted (offcourse you'll take it as the way you are) because you were missing major chunk of what i said and just pressurizing over elements that may prove me wrong.
You have the tendency to talk your own stuff and recite it till the end, I told you that every rooting is Deep Trodden because you get deep into it ,its that simple but people like you looking for tracking people rather than get any original knowledge make such lacy and stretchy useless talks
I suggest again to understand what I write, you yourself are leaning off the topic, The OP wants to do Serial commuication and you took the OTG pathway all the way, I talked about rooting maybe needed for getting the Serial ports emulated. I told him that it maybe needed.
Try just posting stuff that helps the OP rather than making out your own understanding of what the other person means actually.
