Ardriuno Due RTC1307
Hi am trying to set a date and time for RTC with Arduino due but it seems it is not working. I don't know what is the problem with Arduino due.
The same code worked on Arduino mega and it was set.
My Arduino due not reading or writing the date from RTC wiring and connection is fine. The code I used to set the time is mentioned. Does anyone know what can be the problem? It would be very helpful thank you in advance
#include <Wire.h>
#include <Time.h>
#include <DS1307RTC.h>
const char *monthName[12] = {
"Jan", "Feb", "Mar", "Apr", "May", "Jun",
"Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
tmElements_t tm;
bool parse=false;
bool config=false;
// get the date and time the compiler was run
if (getDate(DATE) && getTime(TIME)) {
parse = true;
// and configure the RTC with this info
if (RTC.write(tm)) {
config = true;
while (!Serial) ; // wait for Arduino Serial Monitor
delay(200);
if (parse && config) {
Serial.print("DS1307 configured Time=");
Serial.print(TIME);
Serial.print(", Date=");
Serial.println(DATE);
} else if (parse) {
Serial.println("DS1307 Communication Error :-{");
Serial.println("Please check your circuitry");
Serial.print("Could not parse info from the compiler, Time="");
Serial.print(TIME);
Serial.print("", Date="");
Serial.print(DATE);
Serial.println(""");
bool getTime(const char *str)
int Hour, Min, Sec;
if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
tm.Hour = Hour;
tm.Minute = Min;
tm.Second = Sec;
return true;
bool getDate(const char *str)
char Month[12];
int Day, Year;
uint8_t monthIndex;
if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
for (monthIndex = 0; monthIndex < 12; monthIndex++) {
if (strcmp(Month, monthName[monthIndex]) == 0) break;
if (monthIndex >= 12) return false;
tm.Day = Day;
tm.Month = monthIndex + 1;
tm.Year = CalendarYrToTm(Year);
return true;
https://forum.arduino.cc/index.php?topic=141233.0
ard_newbie:
Arduino due DS1307 RTC library - Arduino Due - Arduino Forum
Hi thank you for your post. I found that wire.h does not work with Arduino due. RTC library worked thank you again for replying
Solved
