ArduIMU: First Arduino IMU test (ArduCopter)
Hello, i found a good family here in http://www.diydrones.com/, is an excellent group of people trying to build an automatic airplane like me, they are helping me with the Arduino automatic pilot and the translation stuff. ::)
Info and source code here: http://www.diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A19829
Don't forget read the comments, i explained a litte bit more about Kalman Filters.
Jordi ;)
That's really impressive code, Jordi. Since you are putting this into a heli, are you planning to make a single PCB to hold down weight? Perhaps a socketed ATmega168 and your sensors, nothing else?
Yes maybe, or perhaps a simple PCB with mini arduino slots on it. ;D I possible to use the same crystal for two atmegas168?
Crystal? I don't think so.
A TTL crystal oscillator, however, is a different story. With careful board layout you may be able to drive multiple inputs with an oscillator.
That will probably require fuse changes, though.
-j
Yes the crystal oscillator (16mhz), CAN I USE one crystal for two atmegas 168??? :-/
OK here is the final version of the ArduIMU.
Video: http://youtube.com/watch?v=1DDEH2n2_hY -Yellow color = Just Accelerometer read -Red color= Accelerometer+Gyro+KalmanFIiter
Arduino Source Code: http://jordii07.googlepages.com/ArduIMUFinal.txt
Labview (ground station) source code: http://jordii07.googlepages.com/IMUfinal.llb
I configured Arduino to externally adjust the accelerometer jitter filter and the gyro rate, using the nunchuck potentiometers (joystick axis). Now is working pretty well.
To do: -Integrate another Gyro (to make it dual axis). -A bank robbery, to buy all the components i need. -Program the SPI altimeter -And put all the hardware together and make it work (gps, altimeter, IMU, modem). -Making a PSP program to read serial data (using psp uart port). ::) to make a portable ground station. (but this is a secret)
