Here is my small project. Arduino based wall clock on 20cm x 20cm double sided board (toner transfer) with schematics, eagle files and arduino code
My second project with arduino
Hope you like it
The clock itself is impressive, but I'm pretty blown away by your ability to etch/drill/via that PCB not to mention the tediousness of soldering all of those LEDs on.
Led's weren't that expensive. 250 LEDs for €22 from ebay, free postage
All the vias were a pain, that's right. Not because of the soldering but it was boring. When I'm doing any layout, no Vias under the parts. That way it makes it much easier.
And to solder the LEDs. I made my own PLCC6 case with the pads little bit out to make the soldering easier. No hassle at all
And also I didn't mention:
Photoresistor for automatic brightness adjust
DHT11 for temperature / humidity
DS1307 real time clock with backup battery
