I searched topic on this forum but the solutions I found here did not work. All I need to is have digispark(USB digistump) added. I saw 2 methods, the old one from preferences adding the .json link which did not work. second one is download a zip file, unzip and run one of the files inside. Both did not work. windows 10 on i5-6300 core. please help. This took so much time.
once I add the json link and press ok, ok, you get a message saying server refused the connection ![]()
Hi @Goldenshuttle. The recommended way to add support to Arduino IDE for Digispark boards is by installing the ATTinyCore boards platform.
Unfortunately there is currently a problem with the website of the creator of that platform (SpenceKonde/DrAzzy), which causes the Boards Manager installation of ATTinyCore to fail:
As a workaround, I have published a provisional Boards Manager URL that will allow the Arduino community to easily install this platform until such time as SpenceKonde/DrAzzy can get the problem with the website fixed.
I'll provide instructions you can follow to install ATTinyCore:
- Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open. - Enter the following URL into the "Additional Boards Manager URLs" field in the "Preferences" dialog:
https://raw.githubusercontent.com/per1234/ReleaseScripts/refs/heads/provisional-package-index/package_drazzy.com_index.json
If there are already Boards Manager URLs in the field, separate them with commas. - Click the "OK" button.
The "Preferences" dialog will close. - You will now see a "Downloading index: ..." notification at the bottom right corner of the IDE window. Wait for that notification to close.
- Select Tools > Board > Boards Manager... from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
- Scroll down through the list of boards platforms until you see the "ATTinyCore" entry.
- Click the "INSTALL" button at the bottom of the entry.
- Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
Successfully installed platform ...
You should now see the boards of the installed platform under the Tools > Board menu in Arduino IDE.
There is information about ATTinyCore's support for the Digispark board here:
Please note that the Boards Manager URL I provided in step (2) of the instructions above is only intended to be used as a temporary workaround for the problem with the official Boards Manager URL for ATTinyCore.
You should monitor the bug report at https://drazzy.com/package_drazzy.com_index.json - SSL-certificate expired 3 days ago · Issue #885 · SpenceKonde/ATTinyCore · GitHub and once SpenceKonde reports that the problem is fixed, change the URL in your Arduino IDE preferences to the official URL, which is specified in the ATTinyCore documentation:
