Hi
Has the Fix for FTDI programming been sorted.
I'm programming a stand alone 328 running at 8Mhz using mini core.
I can program with IDE 1.8 no problem , but not with ver 2.
- I have the seriall monitor closed !
Here is the full error log:
FQBN: MiniCore:avr:328:clock=8MHz_internal
Using board '328' from platform in folder: C:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3
Using core 'MCUdude_corefiles' from platform in folder: C:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3
Detecting libraries used...
C:\Users\house\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g -IC:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3\cores\MCUdude_corefiles -IC:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3\variants\standard C:\Users\house\AppData\Local\Temp\arduino\sketches\C59C67C0A2163A7D3FBC0CDEE2C8680B\sketch\EEC_Fuel_pressure_controller_328v.3.ino.cpp -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
C:\Users\house\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g -IC:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3\cores\MCUdude_corefiles -IC:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3\variants\standard -IC:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3\libraries\EEPROM\src C:\Users\house\AppData\Local\Temp\arduino\sketches\C59C67C0A2163A7D3FBC0CDEE2C8680B\sketch\EEC_Fuel_pressure_controller_328v.3.ino.cpp -o nul
Generating function prototypes...
C:\Users\house\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g -IC:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3\cores\MCUdude_corefiles -IC:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3\variants\standard -IC:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3\libraries\EEPROM\src C:\Users\house\AppData\Local\Temp\arduino\sketches\C59C67C0A2163A7D3FBC0CDEE2C8680B\sketch\EEC_Fuel_pressure_controller_328v.3.ino.cpp -o C:\Users\house\AppData\Local\Temp\1636581918\sketch_merged.cpp
C:\Users\house\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\house\AppData\Local\Temp\1636581918\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\libraries\\EEPROM\\src" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\sketch\\EEC_Fuel_pressure_controller_328v.3.ino.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\sketch\\EEC_Fuel_pressure_controller_328v.3.ino.cpp.o"
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\EEC_Fuel_pressure_controller_328v.3.ino: In function 'void setup()':
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\EEC_Fuel_pressure_controller_328v.3.ino:108:7: warning: unused variable 'Actions' [-Wunused-variable]
int Actions;
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\EEC_Fuel_pressure_controller_328v.3.ino:111:8: warning: unused variable 'firstbyte' [-Wunused-variable]
byte firstbyte;
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\EEC_Fuel_pressure_controller_328v.3.ino:112:8: warning: unused variable 'secondbyte' [-Wunused-variable]
byte secondbyte;
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\Actions.ino: In function 'void TakeAction()':
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\Actions.ino:103:40: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if ((millis() - currentMillis) >= Interval)
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\Actions.ino:125:40: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\SetupUnit.ino: In function 'void SetUpInputs()':
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\SetupUnit.ino:5:8: warning: unused variable 'infoneeded' [-Wunused-variable]
bool infoneeded = false;
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\SetupUnit.ino:6:15: warning: unused variable 'Datalive' [-Wunused-variable]
static bool Datalive; // sets if data is contiually printed.
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\Voltmeter.ino: In function 'long int SecretVoltmeter()':
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\Voltmeter.ino:29:1: warning: no return statement in function returning non-void [-Wreturn-type]
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\SetupUnit.ino: At global scope:
C:\Arduino projects\EEC_Fuel_pressure_controller_328v.3\SetupUnit.ino:6:15: warning: 'Datalive' defined but not used [-Wunused-variable]
Compiling libraries...
Compiling library "EEPROM"
Compiling core...
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\HardwareSerial2.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\PluggableUSB.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\PluggableUSB.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\HardwareSerial.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\HardwareSerial0.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\HardwareSerial3.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\CDC.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\CDC.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\HardwareSerial1.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\IPAddress.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\IPAddress.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\Print.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\Print.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\Stream.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\Stream.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\Tone.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\Tone.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\USBCore.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\USBCore.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\WInterrupts.c" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\WInterrupts.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\WMath.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\WMath.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\WString.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\WString.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\abi.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\abi.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\hooks.c" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\hooks.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\main.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\main.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\new.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\new.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\wiring.c" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\wiring_analog.c" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_analog.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\wiring_digital.c" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_digital.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\wiring_extras.cpp" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_extras.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\wiring_pulse.S" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_pulse.S.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\wiring_pulse.c" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_pulse.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\variants\\standard" "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\3.0.3\\cores\\MCUdude_corefiles\\wiring_shift.c" -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_shift.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\CDC.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\IPAddress.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\PluggableUSB.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\Print.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\Stream.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\Tone.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\USBCore.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\WInterrupts.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\WMath.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\WString.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\abi.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\hooks.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\main.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\new.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_analog.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_digital.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_extras.cpp.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_pulse.S.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_pulse.c.o"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\core.a" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\core\\wiring_shift.c.o"
Archiving built core (caching) in: C:\Users\house\AppData\Local\Temp\arduino\cores\bc58b2855c4062fffcefb96e9d4ad376\core.a
Linking everything together...
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Wall -Wextra -Os -Wl,--gc-sections -mmcu=atmega328p -w -flto -g -o "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino.elf" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B\\sketch\\EEC_Fuel_pressure_controller_328v.3.ino.cpp.o" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B/core\\core.a" "-LC:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B" -lm
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino.elf" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino.eep"
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino.elf" "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino.hex"
cmd /C echo. && "C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objdump" --disassemble --source --line-numbers --demangle --section=.text "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino.elf" > "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino_atmega328p_8000000L.lst"
Using library EEPROM at version 2.0 in folder: C:\Users\house\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.3\libraries\EEPROM
"C:\\Users\\house\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\house\\AppData\\Local\\Temp\\arduino\\sketches\\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino.elf"
Sketch uses 8448 bytes (26%) of program storage space. Maximum is 32384 bytes.
Global variables use 311 bytes (15%) of dynamic memory, leaving 1737 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\house\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\8.0-arduino.1/bin/avrdude" "-CC:\Users\house\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\8.0-arduino.1/etc/avrdude.conf" -v -patmega328p -curclock -PCOM10 -b38400 -D -xnometadata "-Ueeprom:w:C:\Users\house\AppData\Local\Temp\arduino\sketches\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino.eep:i" "-Uflash:w:C:\Users\house\AppData\Local\Temp\arduino\sketches\C59C67C0A2163A7D3FBC0CDEE2C8680B/EEC_Fuel_pressure_controller_328v.3.ino.hex:i"
Avrdude version 8.0-arduino.1
Copyright see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is C:\Users\house\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\8.0-arduino.1\etc\avrdude.conf
Using port : COM10
Using programmer : urclock
Setting baud rate : 38400
Error: cannot open port \\.\COM10: Access is denied.
Error: unable to open port COM10 for programmer urclock
Avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
with 1.8 I have:
Using port : COM10
AVR part : ATmega328P
Programming modes : SPM, ISP, HVPP, debugWIRE
Programmer type : Urclock
Description : Urboot bootloaders using urprotocol
Protocol : STK500v1 skeleton
AVR device initialized and ready to accept instructions
Device signature = 1E 95 0F (ATmega328P, ATA6614Q, LGT8F328P)
Processing -U eeprom:w:C:\Users\house\AppData\Local\Temp\arduino_build_224376/EEC_Fuel_pressure_controller_328v.3.ino.eep:i
Warning: no eeprom data found in Intel Hex file C:\Users\house\AppData\Local\Temp\arduino_build_224376/EEC_Fuel_pressure_controller_328v.3.ino.eep
Reading 0 bytes for eeprom from input file EEC_Fuel_pressure_controller_328v.3.ino.eep
in 0 sections of [0, -1]: 0 pages and 0 pad bytes
Writing 0 bytes to eeprom
Writing | ################################################## | 100% 0.00s
Reading | ################################################## | 100% 0.00s
0 bytes of eeprom verified
Processing -U flash:w:C:\Users\house\AppData\Local\Temp\arduino_build_224376/EEC_Fuel_pressure_controller_328v.3.ino.hex:i
Reading 8448 bytes for flash from input file EEC_Fuel_pressure_controller_328v.3.ino.hex
in 1 section [0, 0x20ff]: 66 pages and 0 pad bytes
Preparing flash input for device bootloader
8576 bytes in 2 sections of [0, 0x7dff]: 67 pages and 0 pad bytes
Writing 8576 bytes to flash
Writing | ################################################## | 100% 4.27s
Reading | ################################################## | 100% 4.29s
8576 bytes of flash verified
