pkdj
1
Hi I have upgraded my IDE from 1.8.13 to 2.3.4 both running on windows 10 PC.
Took me a while to work out why I was having uploading issues in 2.3.4.
Finally worked out that in 2.3.4 you must close the serial monitor before uploading otherwise there is a "COM port access denied error".
Did not have to do this in 1.8.13.
Is there a config setting in 2.3.4 somewhere that will automatically do this so it operates same way as 1.8.13.
1.8.13 still works fine but thought it was a bout time I upgraded
Not a major issue but just a bit of a niggle.
Thanks
Paul
Hi @pkdj. Thanks for taking the time to share your findings.
Does the board you were using when you experienced this problem have an FTDI FT232R USB chip?
pkdj
3
Its a 5V 16Hz pro mini from AZ Delivery and I'm using the sparkfun USB FTDI interface.
Thanks for the confirmation. The Arduino IDE developers are tracking that bug here:
If you have a GitHub account, you can subscribe to that thread to get notifications of any new developments related to this subject:
Until it is fixed, the workaround you found of making sure to close Serial Monitor (and Serial Plotter) before attempting an upload will be effective.
