srnet:
Try a different GPS buad rate ?
I think I tried them all, but nothing went forward.
HillmanImp:
Sometimes I think the authors of GPS tutorials have done us all a dis-service by encouraging new users to think they can make GPS work without understanding how each component works.
John.
I tried NMEA, unpined tx/rx gps from arduino, then downloaded code like:
// Test code for Adafruit GPS modules using MTK3329/MTK3339 driver
// This code just echos whatever is coming from the GPS unit to the
// serial monitor, handy for debugging!
// Tested and works great with the Adafruit Ultimate GPS module
// using MTK33x9 chipset
// ------> http://www.adafruit.com/products/746
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
//This code is intended for use with Arduino Leonardo and other ATmega32U4-based Arduinos
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
// Connect the GPS Power pin to 5V
// Connect the GPS Ground pin to ground
// If using software serial (sketch example default):
// Connect the GPS TX (transmit) pin to Digital 8
// Connect the GPS RX (receive) pin to Digital 7
// If using hardware serial:
// Connect the GPS TX (transmit) pin to Arduino RX1 (Digital 0)
// Connect the GPS RX (receive) pin to matching TX1 (Digital 1)
// If using software serial, keep these lines enabled
// (you can change the pin numbers to match your wiring):
SoftwareSerial mySerial(8, 7);
// If using hardware serial, comment
// out the above two lines and enable these two lines instead:
//HardwareSerial mySerial = Serial1;
#define PMTK_SET_NMEA_UPDATE_1HZ "$PMTK220,1000*1F"
#define PMTK_SET_NMEA_UPDATE_5HZ "$PMTK220,200*2C"
#define PMTK_SET_NMEA_UPDATE_10HZ "$PMTK220,100*2F"
// turn on only the second sentence (GPRMC)
#define PMTK_SET_NMEA_OUTPUT_RMCONLY "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29"
// turn on GPRMC and GGA
#define PMTK_SET_NMEA_OUTPUT_RMCGGA "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn on ALL THE DATA
#define PMTK_SET_NMEA_OUTPUT_ALLDATA "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn off output
#define PMTK_SET_NMEA_OUTPUT_OFF "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
#define PMTK_Q_RELEASE "$PMTK605*31"
while (!Serial); // wait for leo to be ready
Serial.begin(57600); // this baud rate doesn't actually matter!
mySerial.begin(9600);
delay(2000);
Serial.println("Get version!");
mySerial.println(PMTK_Q_RELEASE);
// you can send various commands to get it started
//mySerial.println(PMTK_SET_NMEA_OUTPUT_RMCGGA);
mySerial.println(PMTK_SET_NMEA_OUTPUT_ALLDATA);
mySerial.println(PMTK_SET_NMEA_UPDATE_10HZ);
if (Serial.available()) {
char c = Serial.read();
Serial.write(c);
mySerial.write(c);
if (mySerial.available()) {
char c = mySerial.read();
Serial.write(c);
and when I put gps TX to pin 8, its starting to output to console. Other pins are not outputting anything. But anyway the output looks like previously - im getting some weird symbols.
Get version!
G⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sf⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sf⸮cF⸮cF⸮jDG⸮ʃ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jCG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʃ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʃ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sf⸮cF⸮cF⸮G⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sf⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʋ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jEG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮,TN⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jD#⸮j⸮⸮G⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jD⸮G⸮ʂ⸮Sf⸮cF⸮cF⸮jD⸮⸮⸮⸮⸮G⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʃ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cH⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jD⸮⸮⸮⸮c⸮⸮G⸮T⸮N⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʃ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮⸮G⸮ʂ⸮ST⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮cF⸮cF⸮jDG⸮ʃ⸮Sg⸮cF⸮cF⸮jDG⸮ʂ⸮Sg⸮⸮⸮⸮⸮/
There is documentation here:
https://pl.aliexpress.com/item/32951163811.html
Which says baud rate for this gps: (default 9600) can set 1200,4800, 19200,38400, 57600,115200 bps
Anyway, when I set 115200 for this gps, the results look more normal than previous (on 9600).
Get version!
$GNRMC,,V,,,,,,,,,,N*4D
$GNVTG,,,,,\,,,N*2E
$G⸮GGA,,,,,,0,`0,$GNRMC,,V,,,\,,,,,,N*4D
$GNVTG,,,,\,,,,N*2E
$⸮NGGA,,,,,,0\00,99.99,5,,,9
,,9.$,G0GV$GNRMCL,V,,,,,,,,,\N*4D
$GNVT⸮,,,,,,,,,N*bE
$GNGGA,,,,,,0,00,99/99,*A,99E,,)⸮b⸮rR5$,L*L*$GNRMC,,⸮,,,,,,,,,,NZ4D
$GNVTG\,,,,,,,,N*2E
$GNGGA,,,,,,0,00,99.9y,*G,,9E,,,^Pbb⸮
L0L,$G⸮RMC,,V,,,,\,,,,,N*4D
$GNVTG,,,,,,\,,N*2E
$GN⸮GA,,,,,,0,`0,99.99,5A,.9G,,8*V9,
,7$GNRMC,,V,,,,,,,\,,N*4D
$GNVTG,,,,,,,,,O*2E
$GNGG⸮,,,,,,0,00,y9.99,,G,,99G,,9*V
,6,A$GNRMC,,V,,\,,,,,,,N*4D
$GNVTG,,,,,,,,,N*2E
DGNGGA,,,,,,`,00,99.99,,S,,.2,,.9G1
1NV$GNRMC,,V,,,,\,,,,,N*4D
DGNVTG,,,,,,,,,N*2E
$G⸮GGA,,,,,,0,`0,99.99,5A,99
1,99G*,
,7$GNRMC,,V,,,,,,,,,,⸮*4D
$GNVTG,,,,,,,,,N*2⸮
$GNGGA,,,,,,0,00,99.y9,,
,,9.$,,)⸮⸮⸮⸮R5$0G*L7$GNRMC,,V,,,,,,,,,,N*4⸮
$GNVTG,,,\,,,,,N*2E
DGNGGA,,,,,\0,00,99.99,,⸮,,92,,99
1
,$GNRLC,,V,,,,,,\,,,N*4D
$G⸮VTG,,,,,,,,\N*2E
$GNGG⸮,,,,,,0,00,99.99,6A,9,
A,,)⸮⸮*
V
,A$GNRMC\,V,,,,,,,,\,N*4D
$GNV⸮G,,,,,,,,,NZ2E
$GNGGA,\,,,,0,00,9y.99,
A,,9G,,,9$,L0L*$GNRMC,,V,,.,,,,,,,N*4D
$GNVTG,,,,\,,,,N*2E
$GNGGA,,,,,,`,00,99.99,,N,,9.$,,.9S91
DGNVTG,,,,,,\,,N*2E
$GNGGA,,,,,,0,00,99.99,
1,99G,9,$,
Im not sure, if its about baud rate, gps is broken or its not getting any signal ?
