pito:
I ran the enhBasic with above trigonometric test under arduino @16MHz (no video mess) and it took 84secs/
Then I ran it under the second system (also the enhBasic,no video mess) and it did it in 8.1sec. So my understanding is the second system is ~10x faster than the arduino @16MHz.
I don't have the full history or background of EHBasic.
But Microsoft's basic, running on the CBM and Atari 8-bit, is way faster than EHBasic.
With higher precision.
Trust me. Those Basic versions are the fastest in history on 8-bit platforms.
It does not matter because both benchmarks were done under enhBasic. 1284p mighty 84secs, second system 8.1secs.
There is serial i/o in enhBasic, so the video does not interfere into the measurement..
pito:
I cannot compare that under C64 even when run on both systems, as the video (not related to the emulation) messes heavily the results up..
The enhBasic is good for benchmarking (of the emulation speed) on various systems as the serial i/o there does not interfere too much.
Unless some tricks applied I cannot do it easily with C64 as when I stop the video I cannot see the test has finished
With enhBasic you may print start/stop and measure the elapsed time. No video buffer needs to be read.
When you need to compare architectures/compilers running the cpu.c emulator then the best option is to use the enhBasic as it communicates via Serial only. So the error related to the communication with the emulated system (with Basic) is small.
The C64 rom communicates via video stream, where the stream takes a lot of time in comparison to the time spent in the emulator. That issue is the same for my Terminal printing, as well as for your tft video emulation.
pito:
The EHBasic is basically the lower 8K of the MS C64 ROM set.
I don't know what you want to measure?
But I do know that its faster.
People might be interested to see how the cpu.c emulator performs with avr, CM0, CMO+, CM3, CM4, pic32MX, pic32MZ, etc.. compiled with X, Y, Z compilers.. So when they want start to measure the enhBasic running a benchmark is the good option..
That's why I put up the code for a C64 in textmode.
I ran it on pic32mx Fubarino o'clocked 120MHz (compiled with chipkit's compiler, USB serial com), and the below trigo test took about 10secs (C64 V2 ROM). I only read the first half of the bottom line to eliminate video. So it seems there is an issue somewhere (provided mips is ~20% faster than arm and my clock is 30% more yours) For example, if you do not switch CapsLock on, it returns in 1 sec as it does not run the code (the code is empty).. Unless the mips compiler is a crap I would estimate 19.9 secs for your code in the DUE..
PS: The test for reference:
5 REM PITO'S TRIGONOMETRIC FUNCTIONS TEST 0..89 DEGREE
6 REM FOR C64 V2 BASIC ROMS
7 REM BASED ON WELLKNOWN "9 DEGREE" CALC FORENSIC TEST
8 REM ASIN(ACOS(ATAN(TAN(COS(SIN(9.0)))))) = 9.0 IN DEGREE
10 PH = 3.1415926536/2.0
15 REM DEFINE ARCSIN AND ARCCOS
20 DEF FN ASN(X) = ATN(X/SQR(1.0-X*X))
30 DEF FN ACS(X) = PH-ATN(X/SQR(1.0-X*X))
35 REM TR, TD - TO RAD, TO DEG
40 TR = 3.1415926536 / 180.0
50 TD = 180.0 / 3.1415926536
55 REM INPUT IN DEGREE (0..89)
60 FOR D = 0 TO 89
70 T = SIN(TR*D)
72 T = COS(TR*T)
74 T = TAN(TR*T)
76 T = TD*ATN(T)
80 T = TD*FN ACS(T)
90 T = TD*FN ASN(T)
100 PRINT D; "="; T; " DELTA="; T-D
110 NEXT D
120 END
This is the version with transferring deltas only from C64 video RAM to the VT100 terminal (25 rows x 40 columns).
VRAM is a temporary video memory holding "old" characters. We compare the new RAM[] to VRAM and if a difference we print the new character at the VT100 [row,col] position.
Mind you have to have CapsLock on on your keyboard..
