I have trouble getting the display to do as I want it. I'm using the library from here, where I just follow the example given. However, "8.8.8.8." just shows up instead. Why is that?
I drew the circuit in fritz. There are 2 * 6 pins on my display, so in total 12. I couldn't find a display that only had 12 pins, so ignore the 2 outer left pins on the top and bottom.
About the part number, I'm not sure if this is what you're looking for, but this is on the display: SH5461AS
SOLUION: I forgot to check if it was common anode or common cathode. My display was common cathode, but my code specified common anode. Thanks for the help
